On the PentaxOfficial.com website (translated here
Google Translate ) there is reference to using the Digital Camera Utility to "re-develop" old Pentax DSLR images (even jpg's!) to enable the application of some of the modern in-camera 'enhancements' that weren't available in cameras like the
*istD
This works fine for some pictures, usually those taken with a recognised a/f lens, but for some others, usually taken with an old manual lens, the images can only be viewed, but not re-edited.
Does anyone happen to know which EXIF tags are interrogated to decide whether or not to allow an image to be edited?
I can "frig" the system by manually copying the EXIF data from an editable image into one that won't edit, then I can play to my hearts content, but if there were just one or two tags that needed to be changed it might save a bit of fiddling about.
On a side note, much emphasis is made on how backward compatible DCU5 is with the older images, but there's no reference to how one can acquire and use DCU5 if one doesn't have an up-to-date camera with which it would have been supplied! Yes, I know this can be frigged as well, but it'd be nice if the software was made generally available, without having to go around the houses to install it
