Originally posted by que es tu Yes, surprising him with a KP would be fun! I got mine for $747USD which is only 200 more than the K 70. So putting in a little more is still on the table. He learns fast, so it won't take long to grow into a KP or K3. He has shot a little with the KP while I was at work. Yes, he outdid me!
He is evidently proving an advanced-level camera is appropriate in his case, despite his young age! And that price is quite amazing for what it is. What it is- is a rare design incorporating a high-end build and high-end performance. A very high-quality powerful photography tool in a compact form. Even more rare is having that in a modular design where that form can be expanded as the need arises! Try to find that in any other high-end class APS-C body of any brand. The KP might even be discontinued after the arrival of the new APS-C flagship, so get the unique KP while it is still here!
I'd also recommend eventually if not right off, getting the battery grip to allow maximum modular expansion, with high-level pro capability, definitely better balance with heavier lenses (in his future?), much more convenient vertical shooting, and much longer battery life so if shooting an event you don't have to be interrupted by battery changes. The weight will still only be about the same as the K-3 II by itself, yet with even greater battery life capability! Get the larger D- L190 for the grip, the same battery used in both the K-5 and K-3 series, but in the KP battery grip will be in series with its own smaller battery. A good idea too, get 1 or 2 extra of the standard batteries- I got a couple of Watson brand from B&H, which have been fine. The grip would likely be discontinued if the KP is. As you know, the KP is a compact beast of a camera, but a beautiful beast. I like mine in the silver/black 2-tone, but to each their own taste. Both finishes are of fine quality. With the grip it becomes a very impressive beast! It becomes something the K-70 could never be. If he should hold the KP with the grip attached, no doubt he'd get very excited- it is that different and impressive. By having two KP's this accessory could be used by various family members.
Does he know yet about varying depth of field (DOF) by varying aperture settings? Of either freezing action or showing some blur to show movement by varying shutter speed? These effects, as well as varying exposure according to especially challenging lighting conditions or for special effects by varying exposure? Or by using a fast lens (having wider aperture capability) which can provide adequately faster shutter speeds for shooting moving subjects with indoor lighting without flash? Or reducing DOF to blur background to make a subject stand out from it? These are just a few things one can control with a good DSLR that even the best phones cannot accomplish.
Do you know about the exclusive Pentax Hyper system?
In "M" Manual mode, you can exercise "Hyper Manual" simply by using the green button to instantly set meter-centered exposure instead of having to twirl the thumb (aperture) and finger (shutter speed) dials to get a meter-centered reading. This is extremely efficient, especially when taking meter readings of lighting around a scene to determine your exposure under tricky conditions. Then once you have the exposure value you wish, if you want to change the shutter speed (motion) or aperture DOF) next hit the AE-L button to lock the exposure, then as you select your aperture or shutter speed, the other will automatically follow along to preserve that exposure value. No other brand has this capability.
In the "P" Program mode, where the camera selects both aperture and shutter speed for fully automatic exposure, you can go into "Hyper Program" if you want to alter either aperture or shutter speed and override what the camera has chosen- simply by using the thumb or finger dial to instantly make your selection! You have then instantly switched the camera to either Tv or Av operation, and can instantly make your selection without having to first change the mode dial to Av or Tv! Very fast and efficient for making adjustments on the fly. Your selection will stay put until you restore full "P" operation by just a touch of the green button, or turn off the camera! No other brand has this capability. The K10D, K20D, K-5 series, K-3 series, the K-30, K-50, K-S2 and all current Pentax DSLR cameras have this design. it goes all the way back to the top Pentax 35mm bodies of the mid-1990's, but not all models had this feature until the more recent Penax model lineup.
I've used numerous Pentax DSLRs. Nearly all can deliver very good JPEG images right out of the camera. But I've found the KP's in-camera processing engine to be exceptional for right out-of-camera very fine highest quality JPEG results. If wanting this convenience rather than always going to post processing, the KP is tops. My usual tip for this, be sure first avoid having your mode dial set to the green auto mode, as the camera will be choosing many parameters based on what it "thinks" you will want, and most controls are disabled, and most adjustments are disallowed. Use the "P" mode if wanting fully automatic exposure. Then also set up "Fine Sharpening" in the Custom Image menus, especially in the most often-used "Bright" category. These are accessed via the "info" button, then after the quick adjustment screen comes up, the 4 buttons surrounding the "ok" button become navigation buttons. You should see the Custom Image department right away. It might already be on the "Bright" category by default, then you can go into its menu to implement "fine Sharpening" by using your thumb dial to put an "F" by the "S". This will allow exceptional fine detail to be realized in your images. The better the lens, the more this will be true.
Tips for future quality lenses- For a "fast" pro-style all-purpose zoom lens, the Sigma 17-50mm f/2.8 EX DC HSM is a great choice and available at a very good price for a constant aperture f/2.8 lens. Excellent build, quality, though not having WR. Very sharp imaging. I often pair mine with the excellent Pentax DA* 50-135mm f.2.8 SDM WR for a very fine combo delivering exceptionally fine imaging, and for dealing with lower lighting situations, or whenever needing faster shutter speeds or reduced DOF. For very sharp imaging from prime lenses (non-zoom) for little money, both the DA 35mm f/2.4 and DA 50mm f/1.8 are excellent values. The 50mm is a very good portrait focal length and aperture capability, as well as various low-light uses.
