Originally posted by Fogel70 As I understand Sigma SA mount has the same electrical interface and flange distance as Canon EF mount, but the mount itself is similar to Pentax K-mount.
So it may be easier to modify the lenses to fit on a Canon EF camera.
But I'm not sure it is worth the effort for these lenses.
Another major problem adapting Sigma SA mount lenses to K-mount is that aperture is controlled electronically on these lenses, so you would not be able to control aperture if mounting them on a Pentax camera.
From my current knowledge, that seems a strong statement. KAF4 allows for electromagnetic actuation of aperture. Is this known to be incompatible with how it works on SA mount? The location of the pins should not matter if one is making a major modification of the entire mount of the lens - you'd just have to reconnect the pins as needed as part of your modification. Again, assuming the underlying protocol is compatible, but the EF mount is old and Ricoh not generally known for over-engineering. Looking across at what Yongnuo is doing with old EF lens patents, I can't help but wonder what the status of the EF mount patent currently is.
