Originally posted by Martowski Images are coming out grainier than I'd like, I'm sure having to do with this being a bit of a slower lens have having to shoot at a higher ISO.
The K-r is an upgraded version of the K-x, both of which are better for "grain"- actually noise, at higher ISO settings than were previous models, except the K-5 which is close or slightly better. You could gain more than a stop (twice-to-4x the ISO) of performance with a fast lens (capable of a wider aperture) like the very fine Sigma 17-50mm f/2.8 EX DC HSM, which is very reasonably-priced for what it is, and a very well-built lens also. But then your zoom range is greatly reduced, unless you spend even more for the excellent DA* 50-135mm f/2.8 DC WR which is quite costly then you'd need to change lenses often. So one thing to do is keep track of what focal lengths you often use. Those older , faster prime lenses might work for you, but then maybe you will need a zoom lens, and autofocus, for what you are doing.
The K-70 would definitely be an upgrade in a number of ways. it would provide at least one stop, maybe 3 or 4x improvement in ISO even over your K-r. But if going that far, I would say go a bit farther and get the KP- an ultimate upgrade over the K-r- a more durable, pro-level build style body not subject to the aperture solenoid failure sometimes occurring with the K-70, with a far better set of controls (less going to menus) and not all that much more than a K-70, a real bargain for that class of camera. So many things are improved. Better AF, SR, better metering for better exposures, every bit the improved higher ISO with low noise performance and perhaps even more so. Many other advancements and providing both thumb and finger dials over your K-r's single dial. It can make your current zoom lens perform as well or better at higher ISO compared with a big, heavy 70-200mm f/2.8 lens on your K-r, though it does not go to 200mm, if that is what you need. Best to get both if possible!
Bottom line, you can get sharper and better photos with the KP compared with the K-r. along with the higher ISO performance, and numerous other benefits. It even has a dedicated battery grip accessory available for extended battery life for lengthy shooting of events so you will not likely need to be interrupted for battery changes, and it offers better handling and balance with bigger, heavier lenses, along with duplicate controls for shooting in the vertical position, while the K-70 does not.
