Originally posted by beholder3 In this graph you can see how quickly other sensors drop the ball and urge the RAW photographer to use higher ISO settings since just adjusting this in post will provide worse results.
One of the problems is that newer sensors is not that they drop the ball as you would say, They implement a new sensor design that limits how much the sensor will produce noise as you increase the iso. Dual Conversion Gain introduced by Aptina and licensed to Sony
https://www.photonstophotos.net/Aptina/DR-Pix_WhitePaper.pdf
I for one would what this in every camera that I own as it allows me to set the camera as to how I can get the best IQ for the light level I am shooting at.
Originally posted by UncleVanya Isoinvariant sensors were used in a lot of cameras when Sony was mostly creating these as normal practice. I'm unclear why the latest sensors aren't following this path, but I'm order to use the latest Sony sensors these companies are being pushed away from this.
One of the reasons is that there is a added benefit to the user of these sensors, think of this technology Dual Conversion Gain as having a switch in the camera that can give you 2 different Isoinvariant setting on your camera one being for time that you what to use the FWC of the sesnor and the other when you are only using a small portion of the FWC and having the ability to select the best time to use it.
Think of the DCG as having a bucket with another bucket attached to the side of it with a valve you can turn on and off.
Think of noise as the as food coloring sitting on the bottom of you bucket and when you have a large exposure and fill that bucket full of water there is little impact on how much that coloring will tint the overall color of the bucket. Now when we use a smaller exposure by 1/16 of the size ( where most cameras implement DCG) we are only filling that bucket 1/16 full and now that tinting can be seen in our images.
With DCG we still are able to have the same size of FWC with that same amount of food coloring but divided into 2 buckets, when we are not using the FWC of the sensor we can switch off the valve and not use that additional FWC of that second bucket that gives us the ability not contaminate our image with the additional food coloring ( noise ) from that second bucket.
DCG is literally a switch that can control how much noise the sensor will produce and allow the user to select it based on the exposure they want to use
We have had ISO invariant even in the pentax K10d
https://www.photonstophotos.net/Charts/RN_e.htm#Nikon%20D800_14,Nikon%20D850...ntax%20K10D_12
