Originally posted by othar As heating the air will not lead to water condensation it is not necessary to produce a vacuum inside the bag, provided the camera was wrapped inside the plastic bag in the cold and not after going inside.
Correct. I find it easier to push as much air out as possible but that is just a convenience as it makes it easier to grip the camera.
The maximum amount of moisture that can condense is already present in the bag if the camera is put in when outside. By reducing the amount of air in the bag you reduce the amount of potential moisture, but since warm air can hold more moisture than cold as the air in the bag warms it absorbs any moisture in the bag rather than it condensing on the gear.
Regardless, don't expose cold gear to lots of warm, moist air. Keeping the gear in a camera bag or plastic bag until it warms to ambient temperature is good practice both in winter and when going from cold areas (air conditioning) into warm areas. In winter it is possible to have issues coming in to warm, moist air from outside. But in summer the reverse is true if your home is air-conditioned. Going outside into warm moist from air-conditioning can also cause condensation.
