Originally posted by BigMackCam
Again, congratulations to @mikesbike on what I think is a fantastic choice - and my apologies for the slight OT detour
No apology needed. In fact my post really does touch upon my own reasoning for not going for the K-3 III, instead for the K-1 II, and I did take into consideration the factor of possible near-equal higher ISO performance of the new camera, as well as the VF being "almost" as good. I figured this might be true, so what other advantage does the K-1 II bring? I mean, the K-3 III will already be a quarter-pound heavier than my KP! And the K-1 II's VF is not "almost". Then the K-1 II has the articulating rear screen advantage, and the potential for even greater resolution- if one already has the lenses for that possibility. As I said in your other post, the DA 21mm is a great all-around prime lens. But on FF, my FA 35mm f/2 or certainly the FA 31mm f/1.8 can easily outperform it, with a 1-2 stop advantage, and provide a similar image shot at the same distance, but having a 36mp advantage vs a 24 or 26mp of the K-3 II, KP, or new K-3 III. And these smaller lenses make the added weight of the K-1 II far more manageable. My KP makes a great "sidekick" to complement the K-1 II, and also as an alternate when maximum portability is needed, because it is a full 11 ounces less as well as far less bulky! So this emphasizes the best advantages of both worlds, and with a full complement of useful features for each.
But thank you for being so thoughtful- you are indeed a very considerate person!
