Originally posted by tibbitts I once owned a K100, and even now still own (although I don't know exactly why - could be the roughly $20 value) a K200. Having said that I'd strongly suggest not acquiring yet another body from that same era. It's limiting enough for me to still be stubbornly using K-5 bodies and not be able to use any recently-developed KAF4 lenses. In the 6mp K100 era I might have had AF problems but it wasn't enough to notice given the sensor resolution and lenses I had. The Tamron 17-50 was my introduction to AF problems on the K200 (the K100 was gone by then.) It needed a different adjustment than other lenses. It also needs different adjustments at different focal lengths, and I assume all future Pentax bodies will have that capability.
Hello... unfortunately, your advice came too late. Or should I say fortunately?
Indeed, my "new" K200d arrived last friday and I went for a walk with it this WE. All I can say is that mounted with a Pentax SMC-DA 18-135mm, it produces gorgeous images. I have absolutely no regret. When using my DA* 55mm f/1.4, I noted a very slight back focus I could easily correct with the DEBUG mode (+40 um). This back-focus was also perceptible in close photography at 135mm, but the same +40um in-body correction fixed it. I am maybe lucky, but it seems that the few lenses I own are well calibrated and that the in-body correction on my K100D and my K200D applies equally to all of them.
What I like about these two bodies are
- ease of use: I like the capture modes directly accessible with the mode dial very much. I use it most of the time.
- fewer pixels means faster post-processing and less space consumed on hard drive or cloud... therefore a smaller ecological footprint. It is true that 6 megapixels is short in some circumstances (like printing larger than A4), but even today, 10 megapixels is enough for the most of us.
- the image quality with the lenses I own.
So, yes, I would recommand it to anybody starting photography, with the
WR combo 18-55mm and 50-200mm for around 120 euros.
François
