Originally posted by stevebrot If you are viewing your 24" monitor at 12", you are sitting too close; either that or you need glasses.
No that is an incorrect assumption. The distance is based on viewing an 27" 8k monitor at an optimal distance to see the benefit of a high resolution monitor for a viewer with 20/20 visual acuity. The further away you get from this distance and you will not see the benefit a high resolution monitor brings
So this screen has a width of say 23.5" and a pixel count of 7680, therefore the PPI of this monitor = 326 PPI. The visual acuity distance can be calculated roughly by dividing 3438 by the monitor PPI
3438/326 gives a viewing distance of 10.5" roughly. Closer than my original guess of 12"
Now take the same size monitor but this time a 4k version with a resolution of 3840 x 2160. This monitor has 163 ppi. Visual acuity distance 3438/163 viewing distance around 21"
I am too busy to look up my notes on the calculations for this but you may wish to plug the figures in to a viewing distance calculator such as:
TV Monitor Viewing Distance Calculator – Starico
You really need to sit closer to High resolution TV screen or Monitor than most estimate to see the benefits the added resolution brings.
