Originally posted by ragde What does ".."train" the aperture block .." mean ?
You have to know that the K-70 use a newer solenoid, much more reliable than the previous one. Like the K-S2 made since december 2015. They can fail, but it is much less likely.
In fact, any part of the camera may fail, but this particular problem is dreaded but perhaps it happens now as rarely as any other failure.
I have a K-S2 (manufactured in 2017), which is the model that came before the K-70, since 3 years, sometimes used extensively, sometimes seldom used, with a shutter count of ~18 700, and it still works fine as new!
A KP or a K-3 cannot have such a failure since the aperture block is of a completely different design.
But when the "bad" solenoids are used, the failure was often (but not always) associated with the aperture block being not used at all for an extensive period of time. Like 6 months without any shot, or using exclusively K, M or KAF4 lenses for such a duration
I'd say that actually making use of aperture block
may help preventing this problem. It costs nothing and does not harm the camera, so I think it's better to do it! Actually, unless you use exclusively such lenses (K, M or KAF4), or unless you put your camera in deep sleep for months, you should not worry, as the aperture block will be used anyway.
