Originally posted by UncleVanya So I’m leaning towards buying the grip later if I find it needed.
Right- this is a good plan, as I have seen considerable reductions offered for the battery grip lately. I ordered the battery grip in a deal with my K-5 IIs (then the outgoing model). Mainly because it takes AA batteries. so if I am away on a trip and get careless about keeping batteries charged up, I have this battery grip along with a set of AA lithiums. Now I have this camera along as a backup to my KP, with its battery grip and some AA lithiums. Although as I say, I don't frequently use my KP's battery grip, I do use it more than I have with that of my K-5 IIs. As I think about it, the battery grip is potentially more important with the KP than with my K-5 IIs, other than the AA battery factor. This is because it becomes part of the KP's modular design concept of expanding or contracting its handling characteristics, depending on lenses being used and situations being addressed. You can take it out in its most contracted, compact form with the smallest supplied grip and say a Limited prime, or expand as needed with one of the other supplied grips when using a range of mid-sized lenses, then on into the large, heavier lens category with the battery grip, which converts the KP into a much meatier feel and substantially larger gripping surface. It also provides far more uninterrupted battery life using the larger battery size in the grip in addition to the smaller standard battery in the camera, more than your K-3 without its grip and at a similar weight.
