02-08-2021, 02:47 PM   #16
G&R
To benefit web searching Pentaxians of the future, it appears to me that Pentax made two similar crippled KAF2 lens mounts: installing the wrong lens mount will either not fit, or not restore the camera's weather sealing. It appears K3 are particularly accident prone as evidenced here:
K3II lens mount bent! Viagra won't help this one: Pentax SLR Talk Forum: Digital Photography Review
I bent my lens mount ring: Pentax SLR Talk Forum: Digital Photography Review
In principle I would prefer metal plates held together with plastic pins because, if a lens broke one of those mounts then we would only need to replace the plastic pins. What Pentax have gifted us, however, are metal screws embedded into a plastic base; when the base plastic breaks it is just broken (or replaced with epoxy glue).
02-08-2021, 03:18 PM - 1 Like   #17
By far, most users, even of those regularly mounting very large lenses, never have this kind of problem develop. Otherwise, we would see more than very rare such reports here. Dropping the camera with a large, heavy lens attached would be a very stressful event. Perhaps with other hidden damage as well. Returning this camera for a refund makes the most sense, instead of fooling with it to arrive at less than ideal results. The K-3 body is not plastic, but metal- magnesium alloy. There will likely be even more K-3 and other flagship bodies appearing in the near future, as the new APS-C Pentax flagship, the K-3 III, is due to arrive very soon. You might then find a better deal on a much better pristine, lower-use body.
02-08-2021, 04:33 PM   #18
Seeker of Knowledge
aslyfox's Avatar
as noted by @mikesbike, despite the fact that the K 3 is well built
The K-3 sports a magnesium-alloy body and a steel inner chassis and it's clear that no compromises have been made in terms of workmanship. Nothing on the camera feels flimsy, and its buttons and switches provide great feedback, being neither too loose nor too tight.
Read more at: Pentax K-3 Review - Construction and Handling | PentaxForums.com Reviews
if you drop it, it can be damaged
I've been lucky, when a strap failed and my K 3 fell to the concrete sidewalk, I got minimum damage to the hood of the lens attached and that was all
I expected much worse
02-09-2021, 03:56 AM   #19
G&R
I have dropped my GX10 plenty of times. It bounces.
body, camera, dslr, gap, image, kaf4, kaf4 body, kaf4 mount support, lens, light, middle, pentax service, photography, post, repair, screws, service, warranty
Updated list of KAF4 lenses GregL65 Pentax SLR Lens Discussion 17 57 Minutes Ago 03:42 AM
KAF4 is more than a good idea Kunzite Pentax SLR Lens Discussion 35 02-16-2020 12:56 PM
KAF3/KAF4 to E mount adapter? amstel78 Pentax SLR Lens Discussion 6 08-26-2019 10:36 PM
K-70 bundled 18-135mm lens KAF3 or KAF4? pr0digi Ask B&H Photo! 5 11-26-2017 10:41 AM
K-3 firmware update: KAF4 mount support ScooterMaxi Jim Pentax K-3 & K-3 II 26 12-14-2016 08:22 PM
All times are GMT -7. The time now is 04:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
