Originally posted by Wheatridger When the K-1 arrived, I did attempt to use Pixel Shift. My understand was that you had to use Silkypix to process the image. I loaded that program, took one look and headed for the hills. Too unfamiliar, and the one function I wanted to use was hidden. Are there other programs now that makes the process easier. Can Lightroom handle them?
Finally, the title question- in what situations is it worth it?
Quote: The program you use should have come with your camera on a CD. It is called Digital Camera Utility.
I "resisted" the supplied Digital Camera Utility for a while, not so much "complicated" but certainly unfamiliar, and rather cryptic. The minimal documentation is an issue, but the supplied help file appears to be complete, if not very easy to work with, but well worth having open alongside the program … having two monitors can be useful here
Then I found the Japanese-language pages at
???????RAW??????????Digital Camera Utility 5 ?1??????? | PENTAX official , applied an on-line translator, and much became clear
For my purposes, a far more attractive solution than having to learn a third-party program, especially if I was to be expected to keep paying a license fee!
One characteristic of Digital Camera Utility that I do appreciate is the use of the same terms and descriptions in the program as used on the cameras, so any adjustments that are consistently required in DCU can be easily applied in-camera, thereby saving some post-processing "fiddling"
Sorry, never really tried Pixel Shift, so can't help with that aspect of things, but if you're going to spend time learning a software package anyway, why not use the tool designed specifically for the job?
