Camera trapping is a blast and I wish it would come up more often on this forum.
I've been doing it for a couple years now and it is very addicting. It's taught me a lot about flash photography, scene planning and composition. Finding out what you've caught while away can be like Christmas morning for a child. The biggest downside is you're at risk for having your system stolen when you're away.
I see you purchased the Pluto and I believe I answered the relevant question in that thread. I have the Pluto, but never use it for camera trapping. I mainly bought it for the lightning sensor, but have yet to be in the right place at the right time to capture lightning with it.
If you get serious, it'll require some cash outflow as you'll need to buy or build a camera housing, sensor, flashes, remote triggers and receivers and mounts. There are a lot of DIY options for the sensor, housings and mounts. Cameratrapper.com forum doesn't get a lot of action but has good information. Also look at the "how to" sections and videos on the websites for Camtraptions and Cognysis.
My go to overnight sensor/trigger is the Cognysis Sabre, which provides control over every option imaginable and is probably the best sensor out there. It's pricey and has an internal battery that wouldn't last long enough for a prolonged set up. I like it because I can measure my beam distance, set the number of shots, time between shots and adjust the shutter press duration allowing it to awaken Pentax cameras and appropriately fire the flashes on the first detection of motion. Other sensors may only awaken the sleeping camera with the first detection and may not fire until the second.
Congysis also has a "cheaper" RangeIR sensor which works very well and would last longer in the field. It triggers a single shot and isn't waterproof.
The Camtraptions PIR v3 is the wireless and waterproof sensor I use for setups that are out for a week or two. It's a bit tricky to learn, but works well.
The popular flash for camera trapping is the old (purchased used) Nikon SB28 as it is relatively cheap (going up due to camera trapping demand however) and awakens and fires very rapidly. I use Camtraptions wireless triggers and receivers for all my remote flashes. There was a rumor that Camtraptions is going to make a similar flash, but I have yet to see it.
Here's a link to some of what I've captured over the last couple years. Most are at a watering hole I created to camera trap nocturnal visitors when the weather is warm. At the opposite end of my watering hole is a wooden platform where my camera sits beneath an upside down rubbermaid tub with a hole in the side to shoot through. I've added sound dampening foam to the inside of the tub to deaden the sound of the camera as it's awakened or shooting (this would be a good situation for mirrorless). I have the off camera flashes in modified clear tupperware containers mounted on poles. Everything is painted with DIY camo colors.
Camera trap | Flickr
