Originally posted by Not a Number One or more users on PF have reported some sort of dark frame problems with the K-x. Since there were no follow ups it is unknown if the is the aperture control block failure.
A couple of posters on the German Pentaxian forums have reported finding the green solenoid in place on the aperture control mechanism.
That is a misunderstanding:
Some posters quoted that they found the green solenoid in the pop-up-flash circuit of some Pentax bodies.
I have written about this
HERE because I have found in almost every: K100D, K110D, K200D, K-m and K-x sold in Europe that green solenoid built in there.
It never failed there.
Originally posted by Not a Number I would think that finding a K-x with a green solenoid installed from the factory is very, very unlikely. However a used camera may have had the white solenoid replaced with a green one in order to repair a K-30/50/70 or KS-1/2. Again, unlikely but still a remote possibility.
Every K-x and most K-r had the white Japansolenoid for aperture-control.
Almost 99,9% as you say, if one finds a green Chinasolenoid there, then it was replaced for using that white solenoid for repair.
seventysixersfan
I would not buy a K-x, to me the limitations are too limiting.
You are spoiled with your KP and the 16MP sensor in the K-01 (I don't like the K-01 that much, the screen is terrible in sunlight, reflections are too bad, I dislike having to guess what might be captured and "down under" this might be even more a problem
The K-S1 is far superior but does suffer occacionally from ABF.
Easy to repair, if one dares
Same for the K-S2, but its the K-S1 which is really compact, with the DA40XS the smallest DSLR Pentax possible.
Otherwise, very small and very reliable the old *istD or DS.
No antishake though.
You get that with the K100D or Km (K-Mama).
Latter limitation in AF, just 5 points.
