Originally posted by dms The k-x is a fine camera, and I believe the k-r is basically the same, except you can see the AF sensors
That is one difference, but there are quiet a few more:
- better AF
- 3" display
- better Liveview
- stronger AF motor
- AF-assist light
- double ISO
- Li-Ion + AA (with adapter)
and a few others.
Originally posted by dms ....but it does not take AA batteries.
It was the first to use the D-LI109, but with the AA Adapter same as K30/50/500, one could use AA's
and that was the best, because the powersupply was based in the Kx PS and could produce problems: Mirror-flop!
The other problem was front-focus in low-kelvin light
Originally posted by dms For me AA lithium are great--they last forever, and if I need them for my GPS when backpacking I can take them from the camera. Suggest you get it thru KEH, B&H, etc. so you can check it out on receipt and return if need be w/o hassle. If it works it should last and serve you well, and you have not sunk a bunch of money into it.
I understand your suggestion but this front-focus issue must be known because one cannot solve it via fine-adjust!
Also the mirror-flop was really a problem and yet, many worked alright.
Originally posted by dms I personally don't want the accelerator/too much messing w/ my file data, and given that--I happen to think there is virtually no difference in IQ between my K-5, K-x, K-S2 and Nikon D700.
Well, I experienced the opposite.
The K-5 and particular the K5II/s are a good step higher. The K-5II/s has a better AF, particular in low-light,
it was the first to be more sensitive in lowlight, the K-S2 followed, same f2,8 sensors there.
BTW the K-10D (I have the identical body K-20D) is a much larger camera, and for me is much more dated--anyway it feels very large--and [the K-20D] is inferior to the K-x image wise. Cannot speak to the older sensor CMOS vs CCD.
Here you mix something up:
The K10D has the "older CCD-Sensor" and can be superior to the K-x image-wise but not in low-light.
It still is a might beast, kind of a real masterpiece, a real Pentax.
The K20D is a complete different story, it had the 14,6MP Samsung sensor, one finds that one in the K7 as well.
That was a difficult sensor, for many indeed inferior to the K-x.
But I liked the handling of both, the K10D and K20D (similar bodies, one can swap parts, same as the K7 and K5)
It was the K-m which had the last time this CCD sensor, a small handy body with the limitation of just 5 focus-points
so basically an *ist-DL2 but with shake-reduction.
The larger K100D again 11 focus points.
K200D the same CCD-Sensor as the K10D!
