FWIW - I just finished using a set of eneloops and managed 837 shots - mostly without flash.
However those were charged some 5 months previously (they were carried as spares) and the duration of usage was over about 2 months - so basically at the end of the usage the eneloops were some 7 months from charge.
This shows that the eneloops managed to hold their charge, and more to the point maintained their voltage above the relatively high threshold cut-off of the K100D - whereas I had a set of Kodak Pre-Charged used about 3months from charge that lasted 347 shots to shut-down - however they still had about 44% of their capacity left (shown by discharge in a regulated flashlight) -
see Post #
62 of
eneloop vs. Kodak Pre-Charged Voltage Maintenance
Kodak Pre-Charged are otherwise excellent LSD rechargeables
(from more recent charge they lasted some 671 shots with quite a bit of flash usage)
- it's just for the Pentax K100D's unreasonably high threshold cut-off voltage the eneloops are more suitable - especially if the batteries are used some months after charge.
So with its ability to deliver the demanded current while maintaining the voltage better - I wonder if eneloops would make focussing better/quicker than regular NiMH and how much slower than lithiums.
