Originally posted by McLaughlin Does this camera have a limitation on the capacity of an SD card it can use? I usually use 16GB cards and never fill them up. No Problems. I tried formatting (just to see how it worked) a 128 GB card but it always gives an error message and does not format. If so, what's the limit?
I'm not sure of the answer to your question - but I
can give the following answer: I got some 64gb cards on sale two years ago. They worked correctly at first, but started failing after a few times. I eventually discovered that cards larger than 32gb were formatted using "EXFAT", a mode invented by Microsoft for larger areas of memory, and that eventually caused problems for my cameras other than my Q-7 - which is still using the 64gb card from back then. Since then, I have personally limited myself to 32gb cards, which is plenty large for me.
