Originally posted by UncleVanya New wasabi packs in my k-3 gave nearly the same life as my Pentax batteries. Over time they lost a small amount but not as much as yours. I tend to not store them fully charged as this reduces lifespan.
I don’t know if they will be equal to the Pentax with the new cells. Your experimenting will inform us all.
I don't have any way to know how old these packs were when I got them. The fella' I got all this gear from, took *immaculate* care of his equipment. It all looked new. He labled the pack #1 through #4, so I am sure he took good care of them and rotated them appropriately.
One of the things that really frustrates me about almost everything that uses lithium batteries, is that there is no good way to limit the charging to prevent premature battery wear. If I could even just *see* the voltage while it is charging, it would help.
Opposite of NiCd and NIMH technology, lithium batteries benefit from many small charging sessions, and being kept as close to 50% charge as possible, while those other technologies benefit from full charge and discharge cycles. A "full" lithium cell is generally considered to be 4.2 volts. An "empty" cell is generally considered to be 3.0 volts. The 3.6 or 3.7 volts that is usually quoted as the nominal voltage is at about a 50% charge. I prefer to shoot for about 3.8 volts for my batteries when I am not using them, but this is tricky, because it means that I have to time the charging, or remove the battery from the charger every few minutes and check the voltage with my multimeter. I have found that my power tool batteries, when they drop to one bar, reach 3.8 volts after about 20 minutes of charging on their charger. I will probably figure out the same timing for my camera batteries and store them at 3.8 volts, only topping them off before I plan to use.
The charging limit and discharging limit (e.g. 4.2 volts and 3.2 volts) can be handed by circuits in the battery cells themselves (called "protected cells") and/or in battery *pack*, and/or in the charger, and/or in the camera/tool. I don't know how these limits are handled by the camera battery packs I am talking about here, other than that I know that it is not handled by circuitry in the battery cells as these cells do not have the "protection" circuitry.
