Originally posted by gdub8 Back when I brought the K5, it was because I had a point and shoot on my trip to Australia and was embarrassed, so it was for travel back then.
1.NOW, married life, to answer your question is portraits, kids having their adventures.
2. A DA 18-55mm and a DA* 60-250mm
3. Sharing on the internet, but for good shots, I'll probably Canvas them and hang on the wall.
Welcome to the forum. Since this is what you've got with your K-5 II, and with your stated photographic interests, here are some thoughts and observations-
First of all, as to FF Vs. APS-C, each has advantages over the other. For FF, it is easier to achieve less noise and higher image quality at higher ISO settings, one could acquire a wide angle lens having a fast aperture (f/2 or larger- meaning smaller number), which is virtually impossible with APS-C, and image quality can be superior- depending on the lens used and the framing compared with top quality in APS-C.
I have long had my K-5 IIs. The "s" means it omits having an AA filter, which potentially can allow finer detail in images. I noticed this improvement over the original K-5. Pentax DSLR models developed since have also eliminated the AA filter but have a switchable anti-moire filter system if needed. Now I also have acquired the KP (for over 2 years) and more recently, the K-1 II. I can tell you, the 36mp K-1 II is quite a remarkable camera and a real bargain for such an advanced FF body with an incredible array of features. I can also tell you, the KP is amazing in that its image quality, even for low noise at higher ISO, is quite close to that of the K-1 II for well over 90% of various kinds of uses!! The KP remains my most used camera. Quality is superb.
The 36mp is meaningful mainly when using a much longer and heavier lens to get the same framing from the same shooting distance compared to the best APS-C with a shorter lens of like quality. Otherwise, you might even be ahead with the APS-C camera. If you are using the same size FL lens on both cameras from the same shooting position, you will get a larger picture of your main subject in your frame with APS-C. Then, to get the FF picture to match the size of the APS-C shot, you'd need to crop, which throws out a lot of MPs, and you could wind up with less than the APS-C shot. The K-1 II's design incorporates a crop mode so you can use DA lenses which are cut to APS-C size sensor use without vignetting, and illustrates this point in that when using this mode, the K-1 II is reduced to about the same MP resolution as your 16MP K-5 II provides (but without the AA filter and with even better low noise performance at higher ISO). Conversely, with the same size FL lens, you will get more width in your shot- wider angle with the FF body, compared to APS-C bodies.
A top quality APS-C system is generally more practical for high quality shooting in the telephoto range. You can carry less weight in both lenses and camera body and get more reach for your shots. I generally use my K-1 II with shorter lenses, like wide angle to short tele, and nearly always my APS-C system for general purpose and for longer tele needs.
Taking all this into consideration with your stated needs and present equipment, I see first of all a glaring mismatch between your lenses with the DA 18-55mm at the short end and DA* 60-250mm at the long end. There is a new DA* 16-50mm f/2.8 in the planning stage to keep in mind as a possible future upgrade. Another possibility is the DA 20-40mm Limited. A 3rd and more affordable upgrade would be the DA 18-135mm, which is amazingly versatile and will even perform well at the frame edges out to 70mm. All three will sport very fine build quality and AF performance, including WR construction. It would seem the APS-C system would be better for sitting back at some distance to snipe shots of your kids in action. And someone recommended the FA 77mm f/1.8 Limited, and I can testify- it is a superb portrait lens, is great for much else and with its fast aperture for low light use as well. Though having a stop less aperture, the even smaller DA 70mm f/2.4 is less expensive and very good also. Getting a KP would seem logical in your case (there are still some new ones on shelves at a great price for this high level of camera), and then put that savings towards some really good glass.
