I found in a "special" drugstore for around 3$ a bottle of almost 100% alcohols made of :
- Butylic alcohol : 4%
- Isopropylic alcohol : 2.5%
- Ethanol : 90%
- Distilled water : 3.5%
I tried it on the LCD screen of my K5, it is very volatile and leaves tiny marks that you can remove with a dry cotton...
Could this be used to clean an APN sensor ?
They also sell 100% ether that removes any alcohol marks for around 7€.
Can I make a good liquid using a small % of ether in the mix ?
I know how to build my custom swaps with a special cotton and a piece of thick paper aka bristol.
Can I clean nicely my sensor with all that stuff ?
---------- Post added 05-14-21 at 10:25 AM ----------
And meanwhile, I've found and gonna buy a very good K3 (9000 actuations), premium edition with grip from a Japan store with all accessoires (demonstration body) for ... 580€
What is the differences between the K3 and the K3 mark III ?
