11-25-2008, 09:15 AM   #16
Blue's Avatar
QuoteOriginally posted by HGMonaro Quote
bet it was easier to determine than the life of various methods of making a print!
if my calculations are correct... at 3fps, hooked up to a permanent power supply and with no memory card (can they do that? I don't know) it would only take 9.5hrs to test it
Yes that would yield data for failure. However, it isn't realistic. How many people shoot continuously for 9.5 hours? Except for Tour de Force anyway. The shutter mechanism is likely to heat up in that situation and loose the lubricant as a result. My original comment was something of a quip. I would expect them to do tests like this but over a period of days.
11-25-2008, 03:35 PM   #17
CertEdFriday's Avatar
Shutter actuation count
Well thank you to all who contributed with a reply - I think I get the Picture!!!
Regards
David
11-26-2008, 06:50 AM   #18
netuser's Avatar
Does anyone know what is the pentax stated number of shutter actuations for k200d ?
11-26-2008, 11:40 PM   #19
QuoteOriginally posted by CertEdFriday Quote
Could someone explain the importance of the number of shutter releases a DSLR has recorded in it's life? After a certain number, does the camera need an overhaul or is it for the scrap heap
The shutter as stated is rated for 100,000 clicks. I am not sure how they get this number. My first GX10 died at 38,000. But it is a valid average, and you can get much more than 100,000 or maybe less.
But I would like to add that I believe dSLRs do need tune ups. My extended Samsung warranty of 4 years comes with a free tune up and cleaning, to bring the camera back into factory calibrations. All systems will be checked, AF, SR, yes even the SR can be adjusted. I think overtime many peoples dSLRs may start to fall out of spec slowly and one day they say "hey I don't like this slow to AF, BF/FF camera anymore and it has this problem and that problem" never realizing the performance degradation overtime. I am not sure when, but if your camera has any AF problems or starts to BF/FF or it has close to 100,000 clicks I say its time to send it in to get tuned up. Its not 100% nessesary and only my IMO. But Samsung does offer it for some reason, they probably know something we dont.
11-27-2008, 12:33 AM   #20
QuoteOriginally posted by jamesm007 Quote
It's the same idea as a car. What would happen to your car if you ran it for 100,000kms without changing the oil? Would it even make it that far? Everything that has mechanics in it will require a tune up eventually, especially the precision moving parts of a camera.
11-27-2008, 04:27 AM   #21
netuser's Avatar
QuoteOriginally posted by drewdlephone Quote
True.. but problem is, that depending on your country, this tune up can cost almost as a new body
camera, dslr, photography, shutter
New K7 shutter count dutch Pentax DSLR Discussion 13 08-25-2010 05:09 PM
Shutter count of about 80 on a new K-X? causey Pentax DSLR Discussion 18 05-14-2010 07:01 AM
K-7 shutter count Nubi Pentax DSLR Discussion 11 02-10-2010 10:01 AM
What's Your Shutter Count?? VIXIV Pentax DSLR Discussion 2 12-16-2009 04:48 PM
K-7 Shutter Count brosen Pentax DSLR Discussion 5 10-17-2009 10:48 AM
All times are GMT -7. The time now is 11:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
