11-25-2008, 03:38 PM   #1
What settings affect the RAW files?
What settings affect the RAW files? For instance, if I over expose, or if I set the sharpness to +2, or saturation to -1, etc... I know those affect the JPEG engine, but do they affect the RAW file?
Jeremy
11-25-2008, 03:51 PM   #2
rburgoss's Avatar
To mu humble understanding, RAW is only affected by ISO setting. All other settings (sharpness, white balance, saturation, contrast, etc.) are not affected.
I dunno about noise reduction? Anyone can shed a light here?
11-25-2008, 04:14 PM   #3
Das Boot's Avatar
The only settings that carry over to raw is how you shot it - ie. ISO, Av, & Tv. All the other settings are stored and used by a raw converter, but you do not have to abide by them. They do not affect the file whatsoever.
-Brian
11-25-2008, 04:19 PM   #4
Marc Sabatella's Avatar
QuoteOriginally posted by jeremy_c Quote
Jeremy
Shutter speed and aperture are physical things - there is no way they could *not* affect the file. ISO is also practically a physical setting; it definitely affects RAW data. Those are the three parameters of exposure, so yes, overexposure affects RAW data. But probably nothing else does. I've heard claims that the high ISO NR might, or that D-range might,
Of course, just because changing saturation and so forth doesn't affect the RAW data doesn't mean it has no effect at all. It will affect the preview the camera embeds within the file, so most browsers that display the embedded preview will show the effects of those settings. And some RAW processing programs will look at the settings you made (which *are* stored within the file, even though they don't affect the RAW data itself), and will use them as starting points in performing their own conversions. But you can always override those settings.
11-25-2008, 08:48 PM   #5
Wheatfield's Avatar
QuoteOriginally posted by rburgoss Quote
I believe on the K20 noise reduction is unavoidable.
11-25-2008, 10:29 PM   #6
The slow shutter speed NR (dark frame subtraction - the thing that makes long exposures take twice as long) is unavoidable, and I'm assuming that does affect RAW. The high ISO NR can be turned off or set to weak or strong values, and I'm assuming that's JPEG only.
11-26-2008, 01:48 AM   #7
Well, contrast, saturation and sharpness have no direct effect on the raw data, but they are used for the preview and the histogram you see once the shot is made...
So, be careful with these...
I've put contrast to its minimum, as this setting is the nearest equivalent of what I obtain in ACR from the RAW files.
11-26-2008, 11:40 AM   #8
Moderator PEG Judges
Kerrowdown's Avatar
The settings you mention do not effect RAW files.
11-26-2008, 03:03 PM   #9
PentaxPoke's Avatar
Your question can be answered with one simple word: Exposure. That is the why you don't need to worry about anything else like white balance etc. when shooting RAW. All that matters is exposure (Shutter speed, f-stop, ISO). Everything else is postprocessing.
camera, dslr, photography, settings
How to save stitched RAW files to a RAW file? HermanLee Digital Processing, Software, and Printing 7 07-09-2010 05:51 PM
RAW duplicate images - saving as RAW files jpzk Digital Processing, Software, and Printing 17 02-15-2010 07:01 PM
Do camera settings affect RAW pics when opened? harleynitelite Troubleshooting and Beginner Help 5 12-16-2009 11:27 PM
White balance - does it affect RAW? esman7 Troubleshooting and Beginner Help 12 07-29-2009 05:31 AM
Does the Photoshop RAW converter work with Pentax RAW Files? mconder Pentax DSLR Discussion 3 05-15-2008 12:14 PM
All times are GMT -7. The time now is 07:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
