Hi all,
I have been using my K10D alot lately and recently noticed a sporadic issue with Hot Pixels. Sometimes I would see some, sometimes not. I understand that these can happen at higher Iso settings but even at these it wasn't consistent but it was getting more frequent. I read that hot pixels can happen at higher ISOs because the pixels heat up.I figured that makes sense, so why aren't I seeing these all the time when I shoot Iso 800 on the K10D? I think I answered it. Its not just that the pixels can heat up.. but if the camera is phyiscally hot it can either cause it or make it worse.
This came about because I was out yesterday taking pics...It was in the 90s. I came in was looking at the images and my images had some pretty bad hot pixels. Which I could not understand why. I got to thinking that yesterday was very hot. So I decided to run an experiment... I took a series of pictures from ISO 100-1600 with the lens cap on and camera was " cold"... room temp normal. I then took my camera out and carried it around a bit. Todays as hot as yesterday... Repeated the experiment.
Both set of exposures showed more hot pixels as the Iso went up which was expected.. but the camera that was "hot" had far more hot pixels. That makes sense if you think about it.
Heres two samples.. straight out of the Camera as Jpgs
Iso 800 cold..
cold K10D 800
Iso 800 Hot
Hot K10D Iso 800
You will need to click on the image and blow it up in Flickr to see the Differences.
Just thought I would share this... I'm sure its not news to some here, but maybe it is to others.
Al
