Originally posted by LostViking If you were starting out with nothing, would you go APS-C or Full Frame.
I am more than excited about the new K3 lll,
I have been away from DSLRs since the D was added.
I was almost ready to pull the trigger on the K3 lll.
But I keep researching with the buy once, cry one, saying in mind.
I live in northern Michigan and my primary targets would be wildlife, streams, birds occasionally, some scenics, but no great expanses like Moab.
Normally I would say that would drive me towards the K3 lll. But this area is heavily canopied, and I will be out when the critters are out, early morning and near dusk. So light may be a factor. The image stabilization in the K3 lll is impressive.
I have no attachment to any gear at this point so it's a clean slate.
I will probably look to acquire two lenses, right away, both and good as fast as I can afford, probably 2.8 range.
I like the additional reach of the cropped sensor, but wonder if it my not pay to step up to Full Frame right off the bat,
I gave serious consideration to the Olympus OM-D EM-1 Mark lll, but I keep coming back here.
I have turned out some reasonably decent results with an old point & shoot, but looking to up my game.
I had pro level Canon setup back in the film era, but sold it off.
This is about the best I can achieve with my 6 megapixel beater,
95% will be outdoors, little to no video. At least at this juncture.
Thanks,
LV
Do you have an opportunity to handle and test drive either camera body, perhaps at a camera store or via a rental service? It might help you compare the size and weight differences between the two formats.
I rented a K-1 II with an HD 24-70 f2.8 a number of years ago to compare it to my K-3 II kit and decided at the time I wasn't comfortable with the increase in size and weight of the FF body and potential additional lenses.
I took a fresh look at the K-1 II last year and bought one with a 28-105 after realizing it was a great value for a FF system, particularly since I can use some of my existing Pentax APS-C and film-era glass.
The utility of the K-mount across so many camera models is probably an understated strength of the brand.
As others have said, you may eventually invest in both systems.
Please keep us posted on your decision.
