11-27-2008, 09:28 AM   #1
That funky focus
I'm a new user of a K20D, i used to be a k200d user...
Since i'm with the K20D, i'm unable to get real focus, i've checked with a chart for FFocus and rearFocus but that doesn't seem to be the issue. Probably my technique is weak...Do you have any help or solution, event with a tripod it's very difficult to get perfect focus.
Here is a crop...i shoot in raw
Thanks for the help
11-27-2008, 03:45 PM   #2
Which lens did you use ? Is it one you used previously with the K200D ? And how far were you form the subject ?
11-27-2008, 04:03 PM   #3
StarDust's Avatar
Since you've used an SLR before I'm guessing you have some experience. At first glance it looks to me like the SR is not working. I'm perplexed, switching to a better model should give at least as good a picture as with your previous camera if not better no matter what lens you're using. If you still have the old camera and perhaps a tripod or can place both cameras at the exact same place you can compare both cameras and compare pictures.
11-27-2008, 04:25 PM   #4
ftpaddict's Avatar
The picture has motion blur, not bad focusing. Try it on a tripod and report back.
11-27-2008, 04:27 PM   #5
Aegon's Avatar
1/45 second at 80mm (120 effective).
Try shooting at 1/120 second exposure for handheld. Otherwise, it is going to blur.
11-27-2008, 04:31 PM   #6
creampuff's Avatar
Looks like motion blur...
Shake Reduction is not a panacea for poor technique.
Holding a camera rock steady is a skill.
11-27-2008, 07:53 PM   #7
ManuH's Avatar
Yep, motion blur as others said. Moreover, any stabilization system will be much less efficient at macro distances (I think it's even mentioned in the Pentax manual). For macros, a tripod is a must.
11-28-2008, 01:13 AM   #8
axl
axl's Avatar
I think the 4 posters above me got it right, 1/45 is too slow for 80mm lens, try it at f4 with1/90 1/100 or put it on the tripod to see what happens...
11-28-2008, 04:50 AM   #9
StarDust's Avatar
What I meant to say was that this is clearly motion blur
11-28-2008, 05:38 AM   #10
Motion blur occurs when the object being photographed is moving and the shutter speed is too slow to stop the motion.
Not sure what is being photographed here, but it looks more like camera shake from too slow a shutter speed in relation to the (actual, not "effrective") focal length of the lens.
11-28-2008, 10:09 AM   #11
Marc Sabatella's Avatar
As others have said, that's largely motion blur. But I'd also point out that since you say it was crop, that looks like a pretty busy scene. Who knows if the camer was actually even trying to focus on the specific part of the scene you posted. Without knowing how much of a crop that was, I'd also observe that appears to have been fairly high magnification, and even f/8 doesn't give you unlimited DOF. So chances are petty good something else was in better focus - but with the amount of blur evident, probably nothing would have looked very sharp.
11-28-2008, 10:51 AM   #12
Otis Memorial Pentaxian
As everyone else has said, looks like camera motion to me.
One additional point...When shooting on the tripod, be sure to switch SR off or use the 2 second shutter delay. If the camera is immobile, SR will introduce motion. Go figure...
11-28-2008, 11:42 AM   #13
heliphoto's Avatar
I agree it looks like blur caused by camera motion.
Another thing to keep in mind when using SR is to make sure to wait for the Hand symbol to appear in the viewfinder before you snap the photo. Not doing that is said to lead to blurry images.
camera, dslr, focus, help, k20d, photography
And Funky Was Her Name-O... PointLookout Pentax SLR Lens Discussion 11 08-11-2010 05:13 PM
K100D is acting funky tam67 Pentax DSLR Discussion 4 09-28-2009 07:25 PM
Funky caterpillar treebeard Post Your Photos! 1 09-14-2009 06:36 PM
funky looking lens LDB Pentax SLR Lens Discussion 9 04-23-2008 06:14 AM
funky vs regular Gooshin Photo Critique 7 02-14-2008 04:05 AM
All times are GMT -7. The time now is 01:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
