07-11-2021, 01:50 PM   #1
Pentax K70 Autofocus - Viewfinder vs Live View
I have recently noticed a difference with the (auto) focus of pictures taken using the "viewfinder" as opposed to "Live View". I have looked at the "AF with Viewfinder" settings and they are set to the following
AF Mode = AF.C
AF Active Area = Auto (11)
The pictures taken using "Live View" are definintiely sharper than the ones taken using the "Viewfinder" and I am wondering if this is normal? Any information people can provide would be greatly appreciated.
Thank You
07-11-2021, 02:00 PM - 1 Like   #2
The Squirrel Mafia's Avatar
Live view uses contrast detect for autofocus. It's waaaaaaaaaaay slower than OVF using PDAF, but it's more accurate, hence the sharper live view photos.
07-11-2021, 02:18 PM   #3
jatrax's Avatar
QuoteOriginally posted by GManCan Quote
It isn't exactly normal but it can happen. Live view uses a different focus system than the viewfinder. If they differ the viewfinder system most likely is off. This can be calibrated using Auto Focus Fine Tuning which is menu item 25 on my K-3II but may be slightly different on your camera. Note that tuning the AF of a lens is a process that requires precision and attention to detail. It can help a lot if the lens is off a bit, but unless done right can actually make things worse.
07-11-2021, 02:58 PM - 1 Like   #4
AfterPentax Mark II's Avatar
In case of fine tuning perhaps this method will help you. DotTune – Autofocus Fine-Tuning in under 5 Minutes | TestCams.com I used it and it is quite easy and is very straight forward.
07-11-2021, 03:27 PM   #5
There are really two situations: the same image (well, zoom setting, distance, etc. the same) being inconsistently focused, or being consistently misfocused. In the case of the latter focus adjustment might be necessary and helpful. The challenge for me with focus adjustment is lenses that require different adjustments at different focal lengths or difficult focusing distances, and/or adjustments are required beyond the camera's ability (that's been the case with multiple Pentax lenses I've owned, including brand new lenses - the adjustment range leaves a lot to be desired.) Increasingly now I just use live view and CDAF whenever at all possible. This would be one of the appeals of a mirrorless camera: not having to deal with PDAF adjustments.
07-11-2021, 05:43 PM   #6
Auto focus fine tuning works best with single focal length prime lenses. It is less effective with zoom lenses. The wider the zoom range the more it will vary, generally. They may front focus on one end and back focus on the other. I will fine tune focus on zoom lenses for the part of the zoom range I use the most. I also tend to use a smaller aperture on zoom lenses, creating a deeper depth of field increasing my chance of having the subject in focus.
07-11-2021, 06:05 PM   #7
AF Mode = AF.C
This is continuous AF, which is generally used for moving subjects so the AF will continue to readjust focus to track the movement. At the same time, with AF-C shutter release will not be focus priority as it is with AF-S, so the shutter can fire even if focus has not been fully achieved. With AF-S, the shutter cannot be released unless focus has been achieved, which with a moving subject might mean a missed shot due to the focus not being right on because movement might occur between the time the shutter button is pushed and the actual release- so it won't fire. For accuracy of AF, AF-S is best and to go even further, have the AF sensor points set to center spot only. Then train your camera with that bullseye on a part of your subject having clear detail like a clear edge, use the half press to freeze that focus and move the camera to reframe your shot then press the shutter button the rest of the way down.
Which lens are you using? AF performance also varies between lenses.
07-11-2021, 07:14 PM   #8
I would definitely look at the fine focus adjustment. Have you noticed this with more than one lens? Note that you can set the fine focus for all lenses or specific lenses. I would recommend setting it for individual lenses for the best results.
07-11-2021, 09:00 PM   #9
Thanks for the responses...you have given me a few things to consider when it comes to AF settings I have and how I can "tweak" them to achieve better results with my autofocus!
---------- Post added 07-11-21 at 10:10 PM ----------
QuoteOriginally posted by mikesbike Quote
The two lenses I am using would both be considered "kit lenses". The first is a Pentax 18-55mm 3.5 (DAL) which came with my camera and the second is an Pentax 55-300mm (DA).
07-11-2021, 09:15 PM   #10
DeepThrob's Avatar
I agree, get your autofocus off of AF.C
07-11-2021, 10:41 PM   #11
Otis Memorial Pentaxian
This ^ ^ ^
Those viewfinder AF settings are basically a recipe for frequent mis-focus unless used with great care.
07-12-2021, 12:56 AM   #12
Michail_P's Avatar
Lots of thoughts and advice shared already. I must say though that patience is a teacher. The autofocus of the K-70 is sometimes annoyingly slow.
af, af settings, af-s, auto, autofocus viewfinder vs, button, camera, dslr, focus, k70 autofocus viewfinder, lenses, pentax, pentax k70 autofocus, photography, pictures, press, shutter
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 & K-5 II 2 06-28-2017 04:59 PM
live view noise and smc dfa 100mm f2.8 macro lens not focusing in live view tommygunn84 Troubleshooting and Beginner Help 7 11-24-2016 08:59 PM
K-50 Live View vs Viewfinder (Viewfinder photos Under exposed) jackloganbill Pentax K-30 & K-50 11 06-10-2016 08:01 AM
Typical live view humming, when not in live view. lightsource Pentax K-1 & K-1 II 8 05-05-2016 02:20 AM
K30 Autofocus Issue Live View vs. Viewfinder ivanjiang Pentax DSLR Discussion 13 10-28-2013 04:41 PM
All times are GMT -7. The time now is 06:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
