Hi
I have a question about how the Program mode works with Auto ISO in Pentax K10D. For some reason the Auto ISO seems to only work when in Aperture-priority AE. For example, if the normal Program selects 1/125s and f/6.3 at base ISO 100, it is possible to use the rear dial to adjust the aperture to, for example f/16 for getting a very wide depth of field. In this case, both shutter speed and ISO setting are automatically adjusted to 1/50s and ISO 320.
When the shutter speed is adjusted with the front dial, Auto ISO seems to always stay at ISO 100. Let's again consider the normal Program, which selects 1/160s, f/6.3 and ISO 100. It is possible to use the front dial to adjust the shutter speed up to 1/400s. In this case the aperture is adjusted to f/4, which is the largest for the lens I'm using (SMC F35-80). However the camera does not allow selecting any faster setting than 1/400s, even though Auto ISO is enabled.
Why does Auto ISO only work when the camera is in Aperture-priority AE mode but not in Shutter-priority AE mode? Is this the expected behaviour with this camera? I have been bitten by this functionality on several occasions, when I'm in Program mode and encountering some quickly moving subjects. Getting a decent shot in such situations require some extra fumbling, first manually incrementing the ISO and then selecting a faster shutter speed. Since then I have moved to TAv mode when taking pictures of any kind of moving subjects, because the auto ISO works reliably in this mode.
Here's a pic of the camera settings after pressing the INFO button.
Imgur: The magic of the Internet
I recorded a short video that shows the behaviour of the camera. Hope it's clear enough.
