03-11-2007, 01:19 PM   #1
K110D screen
My brother was using my K110D camera and he asked if there wsa a way tro see what youre taking a picture of on the screen, instead of looking through the viewfinder. I wasnt sure how to answer him so i thought i'd ask if any of you knew?
thankyou,
Amanda
03-11-2007, 01:23 PM   #2
The whole point on an SLR is to be able to look through the viewfinder and see exactly what youre taking a picture of, regardless of the lens.
You can't use the screen like on P&S cameras because there's a mirror and a shutter in the way
03-11-2007, 01:56 PM   #3
Alvin's Avatar
Amanda,
Further to Mo's explanation, there is a mirror that reflects what is seen through the lens into the viewfinder. The mirror blocks the sensor that captures the image until you press the shutter.
If you go into Menu > Setup > sensor cleaning, then choose Mirror up and press ok, take off the lens and you can see the sensor. Turn off the camera when you are done and you will see the mirror go down. Just be careful not to get dust or fingerprints or whatever else in the chamber or onto the sensor.
03-12-2007, 01:32 PM   #4
AndrewG NY's Avatar
"Live" LCD preview is not the norm for SLR cameras--the viewfinder/mirror design is perhaps the fundamental design feature of a SLR camera. The idea is that you see, through the lens, the same thing the film/sensor will see--with zero lag with focus & depth-of-field effects (depth of field visible with the preview lever), and without parallax errors. Works better than LCD in bright sunlight as well.
K110D (K100D & K10D as well) have a digital preview feature where you can see what a picture would look like on the LCD without saving it to the card--but no "live" preview where you can compose using the LCD like a non-SLR digicam.
The feature is activated using the preview lever that surrounds the shutter button (off-on-preview). Whether the lever activates digital vs. traditional aperture stop-down depth-of-field preview is a custom menu setting.
-Andrew
03-12-2007, 03:02 PM   #5
Hi Amanda, welcome back, as others have said the short answer is "no" The longer answer is that it's better to look thru the view finder because you see exactly what you are pointig at, and how it will look. Even more important is the fact that by holding the camera up to your eye, you give yourself a much more stable platform, if you hold the camera away from your body to see the screen it's a lot less stable.
NaCl(good to see you back)H2O
03-12-2007, 10:16 PM   #6
SpecialK's Avatar
Except you don't see quite ALL of the image, and everything tends to be at an eye level viewpoint (unless you like sitting on the ground, etc). I miss the rotating LCD of the A620 which allows more varied camera positions.
03-12-2007, 10:24 PM   #7
-=JoN=-'s Avatar
My optio 33LF did that too, and I thought it was a great feature, but, it's a digital camera, i dont need to worry about film, so I usually just put it where ever and start shooting. If I get anything, fine, if not....oh well.
regardless, you can only really kind of see, framing is still best when you can scrutinize it more in the VF.
03-13-2007, 02:51 AM   #8
Many cameras that use the Four-Thirds mount have this - Live View - but it's really defeating the whole point of an SLR anyway and means there has to be 2 image sensors in the camera.
And given that the Olympus, Panasonic and Leica DSLRs are either bloody unattractive, ridiculously overpriced or failing that still use the 2x crop Four Thirds sensor, you'd have to be a bit silly to buy one.
camera, dslr, k110d, photography, screen
For Sale - Sold: Minolta X-700 Focusing Screen (for you to cut your own split screen) frank Sold Items 3 09-24-2009 10:08 PM
Seeking advice on focusing screen (split screen) for K200D Ari Freund Pentax DSLR Discussion 8 07-31-2009 03:00 AM
Quick Question: Pentax KM screen replaceable with split-focus screen? vinzer Pentax Film SLR Discussion 2 01-06-2009 01:21 AM
For Sale - Sold: K100d and 18-55mm kit lens + split focusing screen installed + glass screen pr vanchaz2002 Sold Items 1 07-24-2008 07:09 AM
All times are GMT -7. The time now is 11:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
