Originally posted by ZombieArmy
Hard to do better than a K-5IIs at that price, though you could probably find a well used K-3 if you need slightly better AF performance and better live view.
The K-5IIs has better IQ and noise performance than the K-3 though, even taking the camera resolution into account.
I agree. The AF performance was upgraded over the original k-5, in addition to its other upgrades.
As to an all-around lens, the DA 18-135mm WR lens on this camera as well as on any other model, will deliver the same fast, accurate and quiet AF while providing fine performance. It is also amazingly compact and well-made for its wide zoom range. I have a number of other alternative lenses, some with more aperture, but of less zoom range, yet this lens is still my go-to when I need its versatility, and I have no worries about its quality. Some have experienced the development of zoom creep. Even after 10 years, I don't have this issue. But I never carry my cameras loose hanging down on a strap. Instead, I use a belt-loop holster case also having the across-shoulder strap as well for stability, weight distribution, and security. I then have instant access when needed, then return the camera to the case after taking my shots. You should eventually be able to find a good used DA 18-135mm at reasonable cost. You can see examples taken with this lens and perhaps some even with the K-5 IIs, in the SLR Lens section under the thread- "DA 18-135mm WR Show us what it can do". Start with the last page, which is the most recent and work backward. One thing at a time, of course. If your need is for a shorter fast-aperture zoom lens, the Sigma 17-50mm f/2.8 EX DC HSM is my recommendation.
