03-11-2007, 04:15 PM   #1
Built-in flash and EV question
On my K100d I cannot use the EV exposure number to get a proper exposure with the built-in flash up. It's always flash -3.0 or -2.5, basically the reading it should show it the flash wasn't up.
Is anyone else having this problem?
Thanks, Peter V.
03-11-2007, 05:43 PM   #2
Alvin's Avatar
Just curious as to what lens you are using, and how far your subject is?
03-11-2007, 05:48 PM   #3
QuoteOriginally posted by Alvin Quote
It happens with both the DA 16-45mm and the DA 40mm, subjects at any distance.
It's like the camera simply doesn't register that I am shooting with flash. :ugh:
03-11-2007, 06:29 PM   #4
Alvin's Avatar
QuoteOriginally posted by nystateofmind27 Quote
NY, sorry, I got (for lack of better wording) killed at work today because I was up late monitoring my network with this Daylight savings time stuff.
I'll need to get back to you on this because I need to get to work very early tomorrow.
Very sorry.
P.S. While messing with my camera in M mode resulting pictures will underexpose if shutter speed too high or aperture too small, even when ev or flash compensation is cranked up to +3.0.
03-11-2007, 06:33 PM   #5
Alvin, no problem at all, i appreciate your replies.
Just check if the EV Monitor shows if the exposure will be proper with the flash up, no EV compensation.
03-11-2007, 06:56 PM   #6
Alvin's Avatar
Always willing to at least try - sometimes not able.
Have a good night
03-11-2007, 07:30 PM   #7
when the flash is up and the camera is in P mode..the ev button alters the flash power.. a minus will simply turn the flash power down.. a plus will simply turn the flash power up..
exactly the same effect as altering the flash power in the menue.. it works and is simple and quick.. but it dosnt show up in the settings.. not so clever with fill flash or anything complicated thow..
trog
03-11-2007, 08:53 PM   #8
Thanks, Peter V.
My GX-1S does the same thing ... the meter will only show the reading that it can take ... It can't really know anything about how the flash will effect the exposure until it is fired.
Barney
03-11-2007, 10:05 PM   #9
QuoteOriginally posted by BarneyCG Quote
Barney
Thanks for the replies.
i see.. I guess it's trial and error but I kind of know that at 1/180 for a subject 4 feet away i can get away with f/13.
built-in, built-in flash, camera, dslr, ev, exposure, flash, photography
K7 built-in flash in M sinus007 Pentax DSLR Discussion 17 08-18-2010 08:22 AM
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
flash guide updated for k-7 built-in flash mattdm Pentax News and Rumors 4 05-26-2009 06:02 PM
best way to use built in flash? furby Pentax DSLR Discussion 8 10-01-2008 01:32 PM
wireless flash using built in flash k200d dtra Flashes, Lighting, and Studio 3 04-04-2008 12:34 AM
All times are GMT -7. The time now is 02:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
