Originally posted by BigMackCam I have a differently-named version of that same extension tube, with the same loose aperture lever. It's very poor quality - plastic tube, poorly chromed body mount and lens mount (with inaccurate tolerance which result in an alarmingly tight fit), aperture lever feels like it's made of tin. I attached it to my old K-5 a couple of times, attached an old lens - without heeding the aperture lever warning - and nearly ended up with it stuck on the extension tube for good. After that, I put it back in the box and initiated a return with the seller, who refunded my money and told me I could keep it (I suspect I wasn't the first to be dissatisfied with the item). I've not bothered with it since...
Lens mounts fine in my case, and indeed, the lever is bit of an annoyance. But it works , I wasn't able to find many alternatives with contacts (none actually), so in the end happy. Quality is sufficient to support even my 300 mm lens in a stable way.
