Originally posted by Emirena Re: all. I don't think I am being held back by aps-c. I'm a huge fan of the k70's user interface, features, and lens quality for prices. I'm very glad I chose to go with Pentax for my first interchangeable lens camera instead of Sony (though their budget point and shoots are great) or an Olympus fixed lens waterproof/underwater tough model that shoots RAW. I will probably get one of the latter for fun sometime, however. Cheaper than a $1000 custom housing!!
My Sony alpha friend said the larger sensor gives a low light advantage but I feel like that's hokum. 24MP is good enough for an 8x10+ print, I don't even have a very large resolution computer monitor (1920x1200 where I do my edits)
I have both the 24mp excellent KP and now also the excellent K-1 II. The KP is great, even better than the K-70, yet even though I don't shoot with Sony, your friend is right in that my K-1 II is still better at higher ISO than is my exceptional KP.
That said, I think you'd be best off with the new K-3 III. The very useful DA 55-300mm PLM lens you have would not yield its full benefits on the K-1 II where you'd have to use it either not over its full zoom range, or in crop mode, where it would provide resolution comparable to an APS-C camera of about 16mp. Your former DA 18-135mm lens is likewise very useful and versatile, but as you said for your uses its aperture limitations were at times an issue, then the obvious choice would be the new DA* 16-50mm f/2.8 PLM lens. I have both a Sigma 17-50mm f/2.8 EX DC HSM lens for these needs, as well as the DA 18-135mm for general purpose. Unfortunately, that Sigma lens is no longer available for Pentax so you'd need to find a good one used. Maybe more of those will come up after the new Pentax DA* 16-50mm PLM has been available for a while. (for my K-1 II I have my very old but excellent Tokina 28-70mm f/2.6-2.8 ATX Pro II for similar framing to my APS-C Sigma 17-50mm f/2.8 lens, but delivering 36mp resolution, and the excellent DFA 28-105mm for general purpose, again able to deliver the superior 36mp resolution but doesn't have as much zoom range as my APS-C DA 18-135mm)
The new K-3 III is close to equal of the K-1 II for higher ISO performance. APS-C offers practical advantages in lighter carrying with better reach for telephoto needs, while the FF K-1 II will deliver superior resolution when comparing imaging using 2 different lenses of similar quality that provide the same framing on both it and the K-3 III when shooting from the same distance. That becomes more and more expensive and heavier, and less and less doable as you go more into telephoto (and is even true of a fast f/2.8 ultra-wide zoom lens). Of course this means having BOTH the K-1 II with the right lenses AND the K-3 III with a fine APS-C lens set, would be the most ideal situation. Then, once you should arrive at this enviable circumstance, you have to ask yourself- how often would you leave the heavier K-1 II behind and take the K-3 III instead, or the other way around?
