Originally posted by normhead So if you have more than 21 lenses that need focus adjustment, based on my experience you probably have 120+ lenses
He only needs 21 lenses. The error can be caused by the camera predominantly, not the lens. It is no coincidence all my lenses (16) require between +6 and +10. The camera's registration distance ... PDAF sensor and the sensor..... is what causes the issue.
You are lucky your camera is spot on, but there are plenty that are not. There is a reason Pentax and every manufacturer introduced the AF/FA menu. To allow for manufacturing tolerances that have always existed, but are only now very apparent with high MP cameras.
---------- Post added 09-28-21 at 05:43 PM ----------
Originally posted by biz-engineer Once a global correction is applied to correct for camera related error (common error to all lenses), there shouldn't be many lenses that still require a lens specific AF fine adjustment. Out of 9 lenses, I have +2 adjustment for one lens (70mm @ f2.8)
You have defeated your own argument here.
If global correction corrects all lenses why do you use a different one for the 70mm ? The fact is that it is the specific camera/lens combo that may need correction.
I completely agree with you that anyone attempting to do a AF/FA without a rigorous empirical approach may be on a fools errand.
