12-04-2008, 02:10 AM   #1
Arpe's Avatar
Help with flash on K20D please
Today I was trying to get my K20D to set at 1/180 with the built-in flash on. I just couldn't figure it out. I'd set it in Av, Tv, TAv etc modes, even M I think, but as soon as I pop up the flash it would go back down to 1/90.
What am i missing?
12-04-2008, 06:04 AM   #2
jeffkrol's Avatar
QuoteOriginally posted by Arpe Quote
What am i missing?
There's a lens dependency for the flash. Check the manual. not familiar w/ the k20 but you should be able to adjust speed in manual mode. W/ my D I can go from anything slower to max sync w/ pop up flash up.
12-04-2008, 06:24 AM   #3
Jodokast96's Avatar
Make sure the camera isn't set to slow shutter sync.
12-04-2008, 07:27 AM   #4
rburgoss's Avatar
QuoteOriginally posted by Jodokast96 Quote
and also check if flash is NOT SET to trailing curtain sync.
12-04-2008, 09:20 AM   #5
Marc Sabatella's Avatar
Are you *sure* you tried Tv and M modes? Those are usually the only ones that would provide direct control of shutter speed when using flash. In the other modes, shutter speed defaults to something like 1 / focal length. The reason being that shutter speed isn't nearly as relevant in flash photography as it is otherwise, since the duration of the flash itself is so short.
12-04-2008, 12:08 PM   #6
audiobomber's Avatar
What am i missing?
My K20D uses 1/180s as the default setting.
12-04-2008, 03:35 PM   #7
Arpe's Avatar
Yep, I had it set to trailing curtain as I was taking some dance show shots, so any ghosting I wanted to appear before the flash.
Thank you all.
camera, dslr, flash, k20d, photography
k20d and Flash Af200S ckons89 Pentax DSLR Discussion 1 08-16-2010 06:16 AM
k20d studio flash fred412 Pentax DSLR Discussion 1 11-22-2009 07:23 PM
K20D and AF-360FGZ flash navcom Pentax DSLR Discussion 3 08-26-2009 06:43 PM
* Best Flash for K20D? * PentaxForums-User Flashes, Lighting, and Studio 6 07-14-2009 04:15 PM
Help with old flash on K20D winglik Pentax DSLR Discussion 5 02-28-2009 06:02 AM
All times are GMT -7. The time now is 03:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
