10-14-2021, 09:55 AM   #1
Battery Shelf Life
Hi All.
I just received a pair of Ricoh-Pentax D-Li90's from a reputable bricks-and-mortar store in western Canada. The manufacture dates are 202012 and 201811. Now there isn't likely to be a problem with the one that's about a year old, but the other one is just about three years old. I was under the impression that the life span of these batteries can be around three years, and it's possible for them to degrade while in an unused condition.
So, is this some unreasonably old stock that I should be sending back? When other people receive batteries, how old are they when they arrive? Should I be squawking at this merchant, with whom I've had decent dealings with to date?
I'm interested in your thoughts.
Derek
10-14-2021, 09:59 AM   #2
bertwert's Avatar
I don't know what the expectation is for buying new batteries - but I have one marked 201210 that still seems to work just as well. Mind you, I don't claim expertise in batteries and I haven't done any battery rundown tests taking videos or pictures or something - but I haven't noticed it running out any quicker now that it's older... So I wouldn't worry about it being 3 years old if it works just fine.
10-14-2021, 10:10 AM   #3
baro-nite's Avatar
I bought my K-5 in late 2012, when it was a discontinued model, so the battery was presumably several months old at the least. I also bought a 3rd-party backup battery. The backup battery failed long ago, but the OEM K-5 battery is still going strong. I use that battery and my K-1 (purchased 2017) batteries alternately in either camera, and still get excellent charge life out of both of them. Your mileage, of course, may vary.
10-14-2021, 10:12 AM   #4
Not a Number's Avatar
I bought a NOS (new old stock) Minolta/Konica battery that has been out of production 6-8 years when I acquired it. Performs to within specs (charging time, approximate number of shots etc.).
I don't think you have to worry about either of them.
10-14-2021, 10:14 AM - 1 Like   #5
vector's Avatar
I had a similar experience buying new D-Li90 batteries that came stamped from 2014 and 2015 (bought in 2019 and 2020). They have been just fine. I am not a battery expert but I believe lithium batteries are rated for a number of charge cycles and are not really impacted by sitting on a shelf in terms of their long term life. The first charge up usually doesn't last too well after sitting but subsequent charges hold up just fine.
10-14-2021, 10:54 AM   #6
UncleVanya's Avatar
If the battery was charged to the recommended 30-50% before being sealed up it is likely totally fine. As far as I know that’s standard practice.
10-14-2021, 11:53 AM   #7
Thanks to everybody! I shall quit fretting about things and instead think about always having a warm spare battery this winter.
10-14-2021, 02:16 PM   #8
Paul the Sunman's Avatar
My oldest is Jan 2011, and seems just fine.
10-14-2021, 02:38 PM   #9
My 2011, 2013, and 2016 D-Li90 batteries are just about as good as new (but they've all been cycled many times since their youth): Battery Capacity / Discharge Measurements - Pentax & Canon OEM versus Generic - PentaxForums.com
Yours are much newer to begin with - I suspect they will be just fine. If there is a window on possible return, I'd run them through a couple of charge/discharge cycles and see if you get about the expected number of shots.
10-14-2021, 06:57 PM   #10
How does one determine if a battery is charged at 30%, 50%, 80%, 100%, or any other % ?
10-14-2021, 09:23 PM   #11
UncleVanya's Avatar
QuoteOriginally posted by DWS1 Quote
With math. You use a known charging current for a known period of time.
10-14-2021, 10:20 PM   #12
Battery from 2012, it's old, I would return it and ask for a new one not from 2012. While a 2012 battery may be working fine, the capacity won't be at its best, especially for the coming years of use.
10-14-2021, 11:29 PM   #13
I have 8 D-Li90 batteries (for 3 cameras, two of which gripped), the oldest one being from 2010, the most recent ones 2020. FWIW, I do not observe any difference in performance between them yet.
10-15-2021, 12:30 AM   #14
QuoteOriginally posted by Ishpuini Quote
It hard to tell any difference without measuring the capacity. I switch off the auto-power-off on my camera fully charge a battery and insert it, let the battery discharge. My new batteries give 6 hours from full charge to full discharge. My 2015 battery give ~ 4h50 discharge time. Hardly noticeable on mixed mode casual shooting ("I do not observe a difference"). But the 6 years old battery has about 20~25% less capacity than the new ones. The question is, even if a 2012 battery works fine now, how much capacity will remain 5 years from now. IMO, they should sell 8 years old Li-Ion batteries as new, that's just wrong, knowing that Li-Ion battery wear out with time even if unused.
10-15-2021, 02:20 AM   #15
QuoteOriginally posted by Bob 256 Quote
You might be confusing Li-I batteries with Lead Acid which was the technology back in the days of mini-disc players. I have a portable Sony full sized disc player which used a thin lead acid pack that sat beneath the player. Lead acid would deteriorate significantly if left uncharged or if they were discharged deeply a number of times. They were best kept at full charge and even then, they would self-discharge over time if not connected to a float charger.
My mistake, they were NiMH, I've deleted my post
batteries, camera, dslr, life, photography
Black & White Ansel On The Shelf lifecameracreation Post Your Photos! 12 11-12-2020 02:26 PM
D-LI90 shelf life of new batteries vector Pentax DSLR Discussion 14 04-10-2019 10:55 PM
For Sale - Sold: Top Shelf Pentax-M 28mm f2.8 with Genuine Pentax UV filter (WORLDWIDE) REDUCED! cheekygeek Sold Items 11 10-09-2013 12:24 PM
See how lenses are made cradle to the shelf... brecklundin Pentax SLR Lens Discussion 6 07-20-2009 01:51 AM
A sunset, or as close as I can get to one! (and a shelf) cputeq Post Your Photos! 3 06-08-2008 06:20 PM
All times are GMT -7. The time now is 07:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
