Originally posted by vector Ok, so I just did some testing on my K1, raw only. I can also fill the buffer and go to 1 shot/sec and still review files and shoot some more while the card writes. In FF mode the playback has a bit of delay if the card is writing but it does do it, and lets you continue shooting again quickly. In APSC mode it can go for quite a long time, and reviewing shots comes up much quicker. I didn't really clock it but I fired off 103 shots in about 2 minutes with a mix of burst shooting, reviewing, shooting some more etc... It works pretty well. So I guess I don't credit the K-70 for being anything special here and if buffer depth and camera interaction while writing are really important then a K-1 in APSC mode wins hands down - even over a K3iii. 15mp is still plenty and if you need more then you go back to FF mode and it's there.
I don't think I've ever shot my K1 in crop mode. If needed I use a crop camera with quite a bit more resolution since I very VERY often do additional cropping in post. Losing 10mb before ever getting to that point would prevent much more than some social posts for too much of it.
I mentioned earlier others may choose differently than I do and if crop mode on the K1 is perfectly acceptable for what you need it for then that's the camera for you and concerts. It works. For me I'd still take one of my crops rather than the K1 if I could take only a single camera.
EDIT: In a K1 test just now I got 9 shots in hi-speed burst, a second or two delay before a 10th, then nothing permitted for about 3 or 4 seconds. After that it does let me resume at about a shot a second, roughly the same speed as the K70 while its clearing its buffer. I guess with the several second delay before even single shots could be taken I hadn't noticed. Thanks for the mention. As long as there's no need for another burst in the next 40 seconds or so it would do the job.
EDIT2: The K3III shoots at a far faster rate than the K1, an impressive 9+ FPS (the K1 hits less than 5) with a burst of 37 frames before it starts to slow down. Even then it allows shooting twice as fast as the K1 and clears twice as fast too, in 15 seconds.
My K-70 is closer to the K1 at 9 shots before the buffer fills but with no delay in continuing to shoot a frame a second and clearing in half the time as the K1. Again thanks for prompting me to check to find the two cameras are closer in burst speed than I had realized, but the K70 still clearing in half the time..
