Originally posted by Michael Piziak How to turn off long exposure noise reduction on the k-s2 ?
With all due respect and great affection, read the manual.
So that it doesn't take forever to process a photo at the end of a long exposure doing astrophotography....
Ther'es two workflows astrophotographers follow:
1) If you have plenty of shooting time, you actually probably WANT this turned on. The camera shoots your light image of the night sky, and then shoots a second image with the shutter closed, and subtracts them, removing hot/warm pixels and lowering overall noise.
2) Shoot a dark frame under the same conditions. e.g. camera completely covered, at the same temperature and exposure length and ISO.
Then you'd subtract the dark frame in post processing later.
That will give you more shooting time under clear skies.
The downside is the camera will get hotter the longer it is on and doing things. So heat builds up, and dark current raises the noise on the sensor.
Shooting the dark at the same time ensures consistent level of dark current in both frames, so it will substract out of the light frame.
If you have a CCD sensor in your camera, this is quite consistent.
The CMOS sensors in newer cameras behave a bit differently, but the principle is the same.
So, the experts will shoot darks at intervals through the night, and build a library of them, or a "master" dark produced by averaging a number of darks.
