If you want to upgrade your AF, none of them. The KP will have better AF than the K-S2 and K-3. The K-3 would not be too far behind, but all reviews point to the KP having better AF.
And the K-S2 is supposed to have the same AF as the K-5II, so I can't see that as being your choice, regardless of the long exposure issue.
More specifically:
1. How can I do long exposures (eg 10 minutes) with the KS2? If this cannot be done, the KS2 is useless to me.
(See
here how to accomplish that)
2. Aside from slightly higher MP count, are there any advantages in the K70 to justify the higher price over KS2?
(14-bit RAW, pixel shift, better high ISO performance, SP protection on sensor to help repel dust and dirt, among others)
3. Is the AF performance in K70 improved over the KS2?
Someone who has had both can better answer that but from what I gather - not that much.
4. What is the white balance/JPEG performance like on the KS2 compared to the K70 or K3?
(White balance gets improved with each new version so the K-3, being from 2013, would be the worst I think. But I like JPEGs from K-S1/K-S2 a lot better than the 24MP sensor in the K-3. Have not had K-70 or KP, but I think they're very improved over the K-3.)
5. How does the AF performance compare in the KS2/K70 vs the K5ii?
(Probably about the same. From what I am told the K-S2 has the same AF as the K-5II.)
6. What is the high-ISO performance on the KS2 like, compared to K5ii nd the others?
(K-5II will be slightly better than K-S2, better than K-3 and worse than K-70 and KP, which would have the best high ISO of all except the new K-3 III)
