As for these features in a dslr. Liveview can use them. The KP can do electronic first curtain with OVF from what I read (never tried it) where only the mirror must go up, the shutter is already open.
Perhaps in some way the extreme readout speed can be leveraged with DSLR bodies in these niche areas.
---------- Post added 12-06-21 at 04:07 PM ----------
Originally posted by luftfluss Yes, eventually.
But who knows if Pentax will utilize the RAM built-in to the sensor in the same way that mirrorless makers currently do. Is it possible Pentax can create some sort of realtime noise reduction?
It certainly means pixel shift would potentially improve. Imagine if all 4 images were taken in 1/1000 s? Movement becomes less of an issue. Frame and focus using ovf, fire using electronic shutter after the mirror flips up, take several shots…
