Originally posted by biz-engineer For your AF test, do you focus with the lens initially pre-focused at nearest focus distance or pre-focused at infinity? If one or the other, do you always pre-focus your lens on the same side when shooting in the real world? I ask you that question because there is difference of AF error whether the lens AF group starting point is on one side of the lens or the other side
I have found a similar situation with a number of my lenses. On my K-3 Mark III, FW 1.31, the optimal AFFA varied slightly depending on the focus direction, but most of the 11 lenses I tested were fairly close and a single AFFA setting works for either direction. One lens did not give a robust solution, so I will always focus that one preset at infinity. On other cameras, some of my lenses showed a significant difference in AFFA characteristics.
- Craig
