Originally posted by dirwood zooming on live view. I looked it up and just tried it out. Not sure how that'll help focus on the moon when its just a bright glowing ball....Should I have a filter on while doing that or am I just missing something obvious?
Ah yes, sorry, I forgot to say ...... to manually focus using LV zoomed on the moon you need to put the camera in M exposure and either stop down the lens or up the shutter speed until the image darkens and you can see the detail. Then focus. Then change the shutter speed/aperture to what you want to use for the shot itself.
---------- Post added 12-21-21 at 01:21 AM ----------
Originally posted by dirwood Here are a few cropped only images I took last night.
These are a bit underexposed. The camera's meter is seeing the bright light and is rendering it 18% grey *. Best bet is to use manual exposure and look at the histogram after you take the shot. You want the histogram to be registering almost all the way to the right but without clipping (overexposure)
You are using f16/18 which can start to introduce what is called diffraction into your images which can soften them. Use a faster aperture like f8/11.
* The same thing happens if you take a picture of a snow scene. The camera meter tries to render the image as a grey mush.
