12-20-2021, 09:50 AM   #1
MetteHHH's Avatar
Help - self timer button on K1ii does not respond!
I am in the middle of a group shot setting! Argh! Tips?
12-20-2021, 09:59 AM - 1 Like   #2
bertwert's Avatar
As in the top button of the 4-way to switch drive modes?
Have you got it in AF select mode so it's selecting AF points with the buttons - if so, long press the centre button in order to use it for drive mode selection, I'm pretty sure that's how it still works on the K-1, same as previous cameras.
12-20-2021, 12:12 PM   #3
volley's Avatar
I've changed that setting many times unintenionally in both ways ...
12-20-2021, 05:37 PM   #4
There's a walkaround from info and then from menu just to get it done with while you are on the session.
LAter you have to investigate if its a bad setting or a physical problem.
12-21-2021, 07:04 AM   #5
kiwi_jono's Avatar
If you change to focus point select mode, does the button work as an up arrow? If so then it likely a settings or software issue. Otherwise its probably a hardware issue unfortunately.
12-21-2021, 09:07 AM   #6
Ole
Ole's Avatar
Have you by chance hit the lock key which among other things disables the four-way controller?
12-28-2021, 10:00 AM   #7
MetteHHH's Avatar
QuoteOriginally posted by bertwert Quote
That... was the problem exactly!
QuoteOriginally posted by volley Quote
QuoteOriginally posted by shyrsio Quote
QuoteOriginally posted by kiwi_jono Quote
QuoteOriginally posted by Ole Quote
Thanks to all of you for your good and helpful suggestions. It was all a bit silly: My mother in law had one "all-I-want-for-Christmas"-wish, which was a photo of all her children, spouses and grandchildren together. Four of them flew in on December 20th from the US, and I had to rush there from a manuscript deadline workday to get the shot in time to have it printed for Christmas. So, there I was, my brain fried from too much work and a K1ii which (thanks, corona) I had not tried out with a self-timer before. I simply never noticed that centre button before.
Well, that ought to teach me to read the manual...
And now I learned about the lock button too. Thank you Ole!
12-28-2021, 04:11 PM   #8
Ouch, now I remember my first time fonding out about it. I thought I had bricked my camera. Lol
Happy to hear it's all ok now!
button on k1ii, camera, dslr, photography, self timer button
K1ii and the green button bscott Pentax K-1 & K-1 II 11 04-17-2021 02:11 AM
This is quite amazing - "A long exposure timer/self-timer/remote shutter trigger" Eyewanders Film SLRs and Compact Film Cameras 7 01-22-2020 09:14 PM
IS this the real Pentax website? Does Pentax respond to inquiries? vyoufinder General Photography 11 10-24-2017 06:28 PM
K-x AF after self-timer for Self-portrait sir.b Pentax DSLR Discussion 7 12-30-2009 07:53 PM
Does a threaded self timer release work on a P67? Dan Zulu Pentax Medium Format 3 11-16-2008 11:37 PM
All times are GMT -7. The time now is 11:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
