Thanks everybody, also the ones I did not reply to - much appreciated Originally posted by ChristianRock Well... the difference between 1.4lb and 1.8lb might be significant if you're walking with a camera all day long...
That's true, even K-50 felt sometimes as ball and chain around my neck.
Originally posted by ChristianRock On the other hands, if you shoot indoor sports, I'd say the AF of the K-3 III is definitely what you want.
AF is the only thing I really missed with Pentax compared to other brands, and it seems that K-3 III is finally coming close
---------- Post added 01-13-22 at 02:13 PM ----------
Originally posted by aslyfox Unlike the K 3 or K 3 II, neither the KP nor the K 3 III can use AA batteries
About the only advantage of K-50
---------- Post added 01-13-22 at 02:15 PM ----------
Originally posted by aslyfox not sure what that means landscape vs. wildlife ???
Unfortunately both, still with wildlife as priority
---------- Post added 01-13-22 at 02:27 PM ----------
Originally posted by Serkevan That is a hard question! What (and how!) do you like shooting? What lenses do you already have?
I am more shooting along, than having dedicated shooting sessions, as mentioned meanwhile, it is typically outdoors, often next to water and possibly with wet weather (that's what pushed me towards Pentax)
Indeed both landscape and wildlife, also macro (plants, insects), and then cities, architecture and (shyly) street photography.
Edit: In all this answering I did not mention too tough task for K-50: indoor sports (basketball)
I have few zoom lenses, and one 50mm, which I do not use much as it is not WR, shooting mostly with 18-135, and indeed I should indeed invest in lenses, thinking about some primes.
I was thinking about 100mm F2.8 Macro and also 20-40mm F/2.8-4.0 Limited ...
Originally posted by Serkevan The KP is a fantastic camera, but the K-3iii has truly excellent performance. In general, if your budget isn't going to complain, I'd go for the K-3iii... but that depends on other factors too. The three things the KP has going for her are:
-Dedicated flash
-Tilt screen
I never used integrated flash on K-50, always used external one.
Tilt screen on the other hand would be nice, although I prefer using viewfinder
---------- Post added 01-13-22 at 02:31 PM ----------
Originally posted by aslyfox only you can determine the camera that suits you best
I know, but it helps me to exchange thoughts about it
---------- Post added 01-13-22 at 02:35 PM ----------
Originally posted by AnotherVoice I own both. I mostly shoot birds and aircraft inflight. I like the KP for reasons mentioned, but told myself that I would upgrade when Pentax "fixed" 3 things about the KP. 1) Frame rate during burst shooting is slow, and the buffer is comparatively very small. 2) Quicker focus and less hunting with my 300mm/F4 and 560mm. 3) Dual SD card slots are nice, but having an UHS-II capability was critical, again to clear the buffer.
The K-3iii hit all my upgrade requirements plus some more low light capability and lots of customization.
So, now the KP is my primary night/Astro camera (for the articulating screen) and the K-3iii is primary the rest of the time.
But hey, I'm just AnotherVoice...
Very interesting.
I did not think about card speeds, and quick price check on SanDisk Extreme PRO 128 GB gives about 7 time price difference between UHS-I and UHS-II ...
---------- Post added 01-13-22 at 02:37 PM ----------
Originally posted by AfterPentax Mark II Leaning on it, mmm alright, but sleep on it? I agree with the others here that if you just put the question K-3 III or KP an answer might be either difficult or the easiest one to answer. But the advise to buy a KP and add a good lens for the price difference is a sound advise. I enjoy the grip that came with it and it is never off my KP. The 20-40mm Ltd paired excellent with this camera, but the 16-85 is very capable as well. I bought it to upgrade from my K-3 mark II and never regretted it. The poor K-3 mark II now suffers the life of a backup for the KP.
Thanks, I am considering 20-40 as well
---------- Post added 01-13-22 at 02:39 PM ----------
Originally posted by kypfer I own and use both … the ergonomics are somewhat "different"!
The K-3iii is very much in the continuing vein of Pentax DSLRs … if you already own one you'll feel immediately at home with this body, the shutter button and control wheels are exactly where you'd expect them to be!
The designers apparently spent some time fine-tuning the grip and control placement … they got it right!
I bought the K-3iii as an "a/f upgrade". In that role it serves well for wildlife work, mostly birds.
In my mind, the KP was a design exercise, trying to replicate an older camera, with the shutter button on the top of the body instead of slightly in front and the front control wheel added almost as an afterthought.
Having used my KP extensively with the largest of the three grips, 'cos that "looked" most like my other DSLRs, the arrival of my K-3iii left me with a KP with no real job to do , so I started to fiddle around, and found fitting the smallest grip, everything started to make sense!
Although the physical measurements of both cameras appear similar on paper, the KP with the small grip "feels" very much more compact in the hand. There's no big right-hand bulge, just so much more "retro". In my hand, the shutter button placement seems so much more natural with the smallest grip fitted (wish I'd realised that earlier!!)
With a "standard" zoom (eg. 18-50mm DC WR RE) fitted and some telephoto capability in my bag (FA 100-300mm or modern equivalent) the KP is an ideal "
outdoor and travel companion". The built-in flash makes it just that little bit more flexible … if I was using the K-3iii for that purpose I'd want to have a separate flashgun, just in case
The KP is also some 100+gm (4oz) lighter, a thought if you're carrying it for any distance.
The KP's autofocus is very good, especially with the latest firmware installed. Not stellar, like the K-3iii, but a very significant step up from the earlier firmware and even more so from the earlier cameras. Inevitably, both cameras will benefit from a wider aperture lens if being used for indoor sports! On paper the K-3iii has an extra stop of low light sensitivity, EV-4 against EV-3 for the KP, but only with an f/2.8 lens!
I've absolutely nothing to say against either camera, they are both superb, but inevitably the K-3iii is even "more superb" … even if you do need a separate flash
Just my tuppence worth … having used both cameras I thought there might be something of use in my ramblings
Very interesting, especially about KP grips, thanks for your "ramblings "
---------- Post added 01-13-22 at 02:44 PM ----------
Originally posted by stevebrot Agreed, though 880 Euro for a KP seems high (assuming used) unless one truly wants that model. If NOS, 880 Euro pricing may be more in line. (Pricing in the EU and Britain can be so different than in the U.S., so I had best shut my mouth, eh?)
Both are new (including VAT)
