I am wondering if any one have a similar problem.
My K3 classic showed (a kind of) mirror lock up symptom while shooing in the snowing nights.
Here are what I can recall:
- It only happens the second time, and both times it was snowing. 0 °C or lower. I never have this issue in another cold nights but not cold enough to snow.
- It was only when I use with the DA21 (small / pancake lenses). There were no such problems when I switch to a lager lenses like DA*55 and DA10-17. Upon switched back to DA21 and here again the issue come back.
- It was only in the first couple of shots when I just change the lens, and when the camera was just wake up from a sleep.
- If I turn off and on the camera, the mirror will go back to work normal and it won't come back until the next time I change lens or after it just wake up. Therefore I don't think it is the same Mirror lockup as the issue people have with earlier K3 unit because I don't have to remove the battery to reset the mirror.
- The battery was not at 100% full when it happened. No such problem when I just start shooting (fully charged battery).
