Originally posted by NaClH2O
Isaac! You have a BIG PROBLEM!!!!!!! Your K20D has been infested with a pixel eating troll!
Wow! i think you are right! That would also explain why my camera has been feeling so much heavier lately! And the unrelated fact that i just added a weather sealed 16-50 could in fact be keeping the troll safe whereas other lenses left it exposed to the elements more.
Your method sounds a little complicated, my friend says mangling a screwdriver around in the front of the body should also work quite well, but should i use a flathead or a crosshead? I wouldnt want to cause any damages by using the wrong type of screwdriver...
In all serious people, i still havent solved the problem that my sensor is somehow bigger when i shoot in raw mode. its even noticeable on the 2.5" display...
