Originally posted by DonV That is what I said, the K1ii at the same sensor size has fewer pixels; perhaps I didn't make it clear enough- I agree with you.
The "crop" feature of the K1 is only equivalent in size and has only about 18megapixels vs 24 for the KP; hence that would be a fair comparison for evaluating the photos.
That is right in principle and reality, except word has it you get about the same resolution as with the 16mp K-5 IIs when operating the K-1 II in crop mode. So yes, that would indeed be a fair comparison for evaluating the photos. Whether 16mp or 18mp, still not close to 24mp. But then, the same principles can be conversely applied going the other direction.
There is also the familiar scene shot with a FF camera with an outline within that scene showing how much less of it an APS-C camera would present, using the same lens FL of course. The area covered is demonstrated to be much greater from the FF shot. But if that greater area was from a 36mp FF camera, and the smaller area shown as covered by the APS-C camera were not an actual APS-C shot, instead simply cropped out of that FF shot, the resolution of that area would only be about the same as if shot by the 16mp K-5 IIs. The rest of the 36mp would be lost with the rest of the image discarded. Another way of showing the above. Clearly, the 24mp APS-C shot of that part of the full-size scene using the same lens of that FL would have the advantage in resolution.
However, if using a shorter, essentially same quality lens in every way, but of suitably less FL on the 24mp APS-C camera to get the same larger area FOV displayed by the 36mp FF camera shot, the scene would be of identical coverage. Then there would be one identical scene made by a 24mp APS-C camera and the other by a 36mp FF camera. No difference in area covered. The one made with the 36mp camera would have the advantage of a 50% gain in resolution over the 24mp APS-C shot. We do this regularly. For example, if we take the well-regarded DA 17-70mm zoom lens on a 24mp K-3II, or under some circumstances better on the KP, we could essentially mimic each photo taken by using the DFA 28-105mm lens on the K-1 II. But these images would not be the same in resolution, since the K-1 II would be operating at 36mp with the same coverage as that of the APS-C cameras operating at 24mp, which is with a 50% gain in resolving power, by the K-1 II, at no disadvantage other than carrying weight.
