Quote: OrenMc: I've never had a problem with my K10D. Maybe part of it it isn't exposing properly. I have been able to get some okay shots with the camera but even then there is always something lacking.
I plan on sending it back Monday but I though I might get some insight before I do.
I can get the camera exchanged but I took some great shot today that should have been keepers. Thats the big bummer.
The first shot is not a bad looking shot. I think the highlight clipping in the background, because of the water's reflection of sunlight, is giving you a less-than pleasant bokeh. Compare that with the shot you like. In the shot you like, the background is much darker, close to the bird itself actually, making for much easier metering. Considering the very difficult metering in the first shot and that it was only shot at f4, it's a decent shot I think.
The 3rd shot is very much underexposed. The EXIF data has been stripped, but a histogram is still available in Photome. The histogram confirms what the eyes see; the shot, where your subject is concerned, is very much underexposed. But, if you look carefully, you'll see there is highlight clipping once again due to the water reflecting light. This too is shown clearly in the histogram. Notice how the ripples, in the highlight areas, are blown to the point where the ripples are not visible. I think this is just another case where you are expecting a lot from the metering. You could have spot metered for the bird (your subject) and you probably would have got a nice sharp bird, but the background would have blown out--which may not have been a bad idea in this case because the bokeh would have been much smoother. If you have a difficult to meter scene like this, you really need to meter for your subject (take the metering controls). You can always crop later. You really can not expect the camera to know what you are trying to do here. The camera simply tried to do what it is supposed to do under these circumstances: it tried to get the best exposure, for the whole frame, while minimizing clipping.
The 2nd shot is more enigmatic. It looks like you may have moved a bit when taking the shot--camera shake. The SR is very effective most of the time, but not in all cases, of course. The metering is good in that the details of the light-colored dock have mostly been preserved, with detail in the rest of the scene staying intact--it just is not a sharp pic--was SR on? What focal length did you shoot at?
I find avoiding noise is sometimes tricky in tough metering scenes. You really need to expose to the right as much a possible, while still getting the exposure you want. You clearly are underexposing here, magnifying noise, even if unintentional.
Also, you have stripped EXIF data--this is often the result of software used to process pictures. Try to use software which does not strip. The pic which you posted with the easy metering scene, from your K10d, still has EXIF data in place. I notice you used a lower ISO in this pic (100). In the K20 shots you have used one and two stops higher--that, coupled with the underexposure and tough scene metering would give you these results--I think. I am no expert, but I hope I have been of some help here.
I remember how hard it was when I first got going with the K20d, metering in particular. In your K10 shot, you used "pattern" metering. If you also used this in the K20 shots which you display here, the results are, I think, to be expected--except for number 2.
I wish you the best. I would not give up on the camera yet. The K20 can take some time to get comfortable with though it is, I think, well worth the effort.
