12-14-2008, 10:00 AM   #1
K110D unable to take photos!
Hi there,
I am in need of help with my K110D, which will no longer take photos. All that happens when the camera is turned on, no matter which lens I use, is the LCD display flashes 'Av --' continuously. I have tried resetting the camera back to factory settings and have changed the lens over but to no effect.
Does anybody know what the problem is? Any help would be much appreciated as this camera provides me with my main source of income in the summer as a watersports photographer.
Many Thanks,
Nick Tayler
12-14-2008, 02:01 PM   #2
Ole
Ole's Avatar
If you use lenses with an aperture ring make sure that you set the ring to the "A" position.
If the aperture ring has no "A" position then you must change a setting in the custom menu to allow the use of an aperture ring.
12-14-2008, 03:35 PM   #3
Thanks for the tip, but it doesn't seem to help at all. Another problem I've recently noticed is that the mode wheel no longer does anything either, I'm beginning to think it may be time for a new body...
12-14-2008, 03:40 PM   #4
ChipB's Avatar
Nick, try changing the batteries and the memory card - they each can cause strange problems. Good Luck!
12-14-2008, 03:40 PM   #5
Canada_Rockies's Avatar
QuoteOriginally posted by nicktayler Quote
First, take out the batteries and leave the camera over night. I got weird effects on my k10d recently, and following tips from others on this forum, I left the batteries out overnight, and the camera was magically "fixed".
03-15-2009, 02:57 PM   #6
K110D problem: any solutions?
I'm having the same problem, and I've tried the batteries out thing,and it still doesn't work. Sometimes the camera will take pictures, but most of the time it doesn't. Any more suggestions? I got this camera because my last pentax broke on me in New Zealand and they said they had fixed it under the warranty, but when i got it back it was still broken.
Also, sometimes, if the camera will take pictures, the shutter will stay open and then i have to take the batteries out of it to get it to close the shutter, and it won't save any pictures if that happens during a burst mode set.
thanks for any help,
alex
03-16-2009, 11:40 AM   #7
Marc Sabatella's Avatar
Assuming you've also verified your aperture ring (if present) is on the "A" position, next step would be to try cleaning the contacts between the lens and camera.
camera, dslr, help, k110d, lens, photography
Unable to control aperture heasley Pentax SLR Lens Discussion 16 05-30-2010 01:55 AM
Unable to fire azngirlLH Troubleshooting and Beginner Help 8 03-03-2010 05:16 PM
Error Unable to submit lens review Mechan1k Site Suggestions and Help 10 11-29-2009 01:42 PM
Error Unable to create new threads deadwolfbones Site Suggestions and Help 8 11-24-2009 11:36 AM
Error Unable to view feedback Kguru Site Suggestions and Help 3 05-05-2008 04:18 PM
All times are GMT -7. The time now is 12:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
