Originally posted by dkpentax Any other things to try before it's sent for an interminably long repair?
- Put a newspaper with lots of text flat on the table.
- Put a small contrasty target in the middle of it (e.g. a six sided die). Not a 2D flat object (but if you dont have anything else a small coin is ok); not single color; not taller than an inch.
- With good daylight (ISO 100, shutter faster than 1/100) aim at the target from near (not exactly and certainly not under) minimum focus distance from a 45 degree angle using the center AF point; using a tripod (so your body movements wont have effect); using AF-S; aperture wide open.
Repeat this with micro adjustement +10 and micro adjustment -10.
Post the 3 images here in maximum pixelcount.
This should make it very easy to see where the focus plane is relative to the intended target.
By the way you could simply have some dust sticking on the optics of the AF system.
